Galvanic corrosion from AC leakage? - SailNet Community
 1Likes
  • 1 Post By Stu Jackson
post #1 of 4 Old 05-02-2012 Thread Starter
I've visited a friends sailing boat and he asked me about a corrosion problem on the propeler "gears" (the teeth part that attach to the shaft), that were completly destroyed.
I did some electrical measurements while the boat was in dry storage:
-There was no AC earth connection.
-There was a leakage current from AC to DC on the battery charger.
-If someone touched the propeler shaft while on ground he would feel a small electric shock from that leakage current.
Since I read that all galvanic corrosion is caused by DC currents, and the only possible current is the AC leakage (since there is no earth connection for the shore power), can this be just regular aging corrosion?
Thanks,
Nuno
nunojpg is offline
post #2 of 4 Old 05-03-2012
Stu Jackson's Avatar
Re: Galvanic corrosion from AC leakage?
There is a major difference between galvanic corrosion and electrolytic corrosion.
Galvanic is between dissimilar metals.
Electrolytic is from electrical issues.
Fstbttms likes this.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #3 of 4 Old 05-04-2012
I don't discuss my member
Fstbttms's Avatar
THIS.
Also, "electrolysis" is NOT electrolytic corrosion. Two different processes.
Fstbttms is offline
post #4 of 4 Old 05-07-2012
The "teeth" you describe are the prop shaft splines, I take it?
The AC voltage, and it's likely to be quite a voltage, will corrode.
You don't need DC for it.
DC (of the same voltage) is more efficient, but AC will do it too.
It just takes longer.
Disable that charger immediately, my friend.
Rockter is offline
galvanic corrosion ezbreezes1 Caliber 2 05-11-2010 08:37 PM
Galvanic corrosion question...... gtod25 Gear & Maintenance 3 04-20-2009 03:42 AM
Bonding/galvanic corrosion Catboatfan Gear & Maintenance 32 10-24-2008 03:22 AM
Rubber = Galvanic Corrosion? sailboy21 Gear & Maintenance 10 02-09-2008 07:50 PM
Galvanic Corrosion Duke 7184 Gear & Maintenance 11 03-17-2007 09:09 AM
