Palmer 60 Electronic Ignition - SailNet Community
post #1 of 5 Old 05-14-2012 Thread Starter
Hi all, I've got a Palmer 60 in my Islander sailboat. I'd like to convert it over to an electronic ignition,,,,,,,,anybody got a part number and source??
thanks, and happy sailing
rlmccb is offline
post #2 of 5 Old 05-14-2012
Tartan 27' owner
CalebD's Avatar
Re: Palmer 60 Electronic Ignition
It seems your choice of electronic ignition module is related to the type of distributor on your P60.
There are EI modules that replace the Delco and Prestolite distributors here: Electronic Ignition--Now available in a Complete Co-It-Yourself Retrofit Kit
and here:
Moyer Marine Atomic 4 Engine Rebuilding and Parts
I'd suggest you call either of these outfits to verify that their EI kit will work for your P60.
Everybody has one:
CalebD is offline
post #3 of 5 Old 05-15-2012 Thread Starter
Thanks, CalebD, this should get me going in the right direction on the electronic ignition,,,,,,,Happy Sailing, Rick
rlmccb is offline
post #4 of 5 Old 09-06-2012
It would be interesting to know how did it go with switching to electronic ignition...
Also, I would appreciate if you (or some other member) could advise me which type and grade of oil need to be used for the gear box on Palmer P60?
Thank you,
Zarko
gemist55 is offline
post #5 of 5 Old 09-06-2012
Tartan 27' owner
CalebD's Avatar
My Atomic 4 likes me to use Rotella T 30W oil.
Not the same engine but similar.
Everybody has one:
CalebD is offline
Palmer P60 overheated rlmccb Gear & Maintenance 6 03-11-2012 11:50 PM
Electronic ignition choices ironworker Atomic 4 1 08-14-2010 12:02 PM
PALMER 60 engine hoagy Gear & Maintenance 5 10-28-2009 09:28 PM
Palmer Johnson 30 owenmccall Boat Review and Purchase Forum 0 03-10-2004 12:42 PM
Palmer p-60 repower ? mrb2222 Gear & Maintenance 0 12-30-2001 10:20 AM
