Link 2000 Issue - SailNet Community
post #1 of 2 Old 05-14-2012 Thread Starter
Learning the HARD way...
eherlihy's Avatar
Link 2000 Issue
This post is for a friend of mine. He claims that his Link 2000 is acting up. I have not been able to check it out personally, but here is how he describes the problem;
The symptoms are that the voltage on the Link says 15.8 even though the
voltage at the battery by the multi meter says 13.4 or so. Also, the Link
2000 isn't registering any charging happening even though I know the Xantrex
is charging the batteries giving the voltage rise when the boat is plugged
into shore power and the fact that they stay up to the proper voltage even
after running the 12-volt refrigeration for 3 days.
The normal connection tests and cleaning the terminals have not resolved the
problem
Thoughts? Theories??
eherlihy is offline
post #2 of 2 Old 05-14-2012
Re: Link 2000 Issue
It is a microprocessor.... has he cycled the power to the Link? It sounds like it's MS 'lockup' mode ....
Faster is offline
Link 2000 replacement wmiii Electrical Systems 11 01-20-2011 02:50 PM
Do you have a link 2000? Capnblu Electrical Systems 13 12-06-2010 06:09 AM
Link 2000 Problem dsbentley Gear & Maintenance 0 04-10-2009 03:58 PM
LINK 2000 R Help needed with regulator Volkhard Gear & Maintenance 27 03-17-2009 07:20 PM
Link 2000 Problem dsbentley Gear & Maintenance 3 10-24-2008 02:52 PM
