KISS wind-generator bearings shot after 2 years ? - SailNet Community
post #1 of 8 Old 05-14-2012 Thread Starter
It looks like the bearings in my KISS wind-generator need replacement, after only 2+ years. The blades don't spin in the wind. I can spin them a little by hand but there's friction and they don't keep spinning hardly at all after I stop pushing them. At such miniscule RPM I don't think magnetic braking is the problem. Unhooked one of the 3 wires to try to eliminate that as a factor; no change.
Anyone else had such early failure of the bearings ? Is this a common problem ?
Thanks,
Bill Dietrich
bill_dietrich@yahoo.com http://www.billdietrich.me/
sailing vessel "Magnolia": 1973 Gulfstar 44 ketch motor-sailer
bdietrich is offline
post #2 of 8 Old 05-14-2012
RichH's Avatar
Re: KISS wind-generator bearings shot after 2 years ?
Thoroughly check the 'magnetic braking', FIRST. Corrosion/oxidation in the control circuit will mimic 'shot bearings'.
Go to Solar Power for Homes, Boats and RVs (USA Kiss distributor) , look at the FAQ listings for remedy, then if you cant continue the 'troubleshooting', contact them directly. 99% of bearing problems are loose/corroded/broken 'control wire' probs.
RichH is offline
post #3 of 8 Old 05-14-2012
Bill, you are in grenada, only 70 or so miles from Dough Billings in Trinidad who makes them. He is a great guy, very helpfull.
gtod25 is offline
post #4 of 8 Old 05-16-2012 Thread Starter
I tried disconnecting one of the AC wires from the control switch; no difference. Guess I'll disconnect all three. No corrosion or shorts anywhere I can see; haven't tried to open the body of the generator.
When I spin the blades slowly by hand, RPM is so low that I don't think enough back-EMF is building up to stop the rotation, if the wires were shorted. Am I wrong ?
I had a tough time getting responses from KISS in Trinidad 2 years ago when I was buying. Will try him again now, after trying disconnecting all 3 wires.
Bill Dietrich
post #5 of 8 Old 05-30-2012 Thread Starter
Got the generator down off the mast, opened up the front cap, and sure enough, the front bearing is toast. Completely rusted and almost frozen. Oil seal ahead of that doesn't look too good, either. Haven't been able to get generator out of housing to look at the back bearing.
This is after 2 years and 4 months of fairly light use, 20 feet up the mast, on my boat in the Caribbean. Seems like an early failure to me. Not happy.
Bill Dietrich
post #6 of 8 Old 06-04-2012
Fortunately, most of the parts are off the shelf and finding a replacement bearing should be easy.
Jim
jentine is offline
post #7 of 8 Old 06-20-2012 Thread Starter
The bearings were easy to get. The machine-shop charged a fair amount to take the old bearings off and press the new ones on, partly because I couldn't get the guts out of the fiberglass housing, and they had to do it. Back bearing probably didn't need to be replaced, but they did both.
Sent email to KISS about several questions a few weeks back, and still have no response from them. I guess they don't read their email.
Bill Dietrich
post #8 of 8 Old 06-20-2012
One of None
deniseO30's Avatar
Sadly not may very good businesses don't use email
My last project!
deniseO30 is offline
KISS Wind Generator cruiserdave Gear & Maintenance 17 07-26-2013 10:18 PM
Rutland 913, Air Breeze, or KISS wind generator? elleandi355 Electrical Systems 20 08-02-2010 08:32 PM
KISS wind generator [Need help - 1] wind_magic Gear & Maintenance 13 06-02-2009 08:38 PM
Is the Kiss wind generator and the Air breeze about the same in noise levels? SanDiegoChip Gear & Maintenance 0 05-27-2009 05:15 PM
KISS wind generator mizzen bracket. maxim_rfeld Gear & Maintenance 0 04-08-2005 08:00 AM
