what size wire for new anchor light? - SailNet Community
 1Likes
post #1 of 13 Old 05-15-2012 Thread Starter
I'm adding a LED anchor light to the top of a mast that has an input current of 0.90 (.065 typical) . The distance from the main battery to the top of the mast is 50 feet (of wire)..what gauge wire do I need to run up the mast? There's a buss-bar right inside the cabin at the base of the mast this mast wire would connect to.
Thanks in advance for help on this. I've got a Don Casey book back at home that has a nifty chart for wire runs & wire sizes I use, but I'm not at home!
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
preservedkillick is offline
post #2 of 13 Old 05-15-2012
souljour2000's Avatar
Re: what size wire for new anchor light?
I'd go 18 guage....tinned wire....for one LED anchor light...and that length run...sure
souljour2000 is offline
post #3 of 13 Old 05-15-2012
killick-
Let's say you are starting with 12.4 volts in the battery, a 100' r/t run of wire, and a 1 amp load. Using 18AWG wire would drop you to just under 11 volts, probably good enough to please the regulator in the LED light but.
Suppose the light wants to see 12+ volts, or it fails and you need to grab a conventional tungsten light to replace it. That's more like a 2A load and you'd need 10AWG wire to keep that at 12v with a 12.4 battery.
I'd suggest that unless you are racing and really trying to keep weight aloft down, you use a heavier guage than the minimum. IIRC the ABYC requires nothing smaller than 16AWG? anyhow, partly because even tinned wire needs some mechanical strength, and heavier wire has better strength.
Depending on what your LED light actually needs to work with? Even at 0.9A you'd need 12AWG to keep 12V to the top. A white LED typically pnly needs about 4-5V, plus some overhead if there's a regulator involved. You might want to ask the maker.
hellosailor is offline
post #4 of 13 Old 05-15-2012
Dog Ship's Avatar
I just replaced my anchor light with an LED and 18 AWG. Although mine only draws .3 amps, you will be fine with 18 AWG.
If you buy a good quality 3 conductor data cable it will have a small wire in it that will work great for hanging it and taking the weight of the cable.
Most if not all LED's will ignite at 9 volts.
If the light packs it in just get another similar one and replace it.
Dog Ship is offline
post #5 of 13 Old 05-16-2012 Thread Starter
Thanks Guys!
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
post #6 of 13 Old 05-16-2012
I believe ABYC specifies a minimum wire size on a boat as AWG16. I'd certainly use that size anyway because of voltage drop alone, as noted in an earlier post.
Bill
mitiempo likes this.
btrayfors is offline
post #7 of 13 Old 05-17-2012
Large Member
This chart?
Sailboat Solar Panel News---Information
mdbee is offline
post #8 of 13 Old 05-17-2012
Dog Ship's Avatar
With the length of 18 AWG? wire I have of 120ft, I have a voltage loss of
.23V.
You have me thinking about what size wire I acually have. I know I upgraded my wind machine from 22 gauge to 18 but I am not sure what was recommended for the anchor light.
I'm going out to the boat today to finish wiring everything up so I will check the size of the anchor lights wire.
Dog Ship is offline
post #9 of 13 Old 05-17-2012
As far as I remember the ABYC minimum for 16 gauge wire is only for a single, free standing wire. duplex wire in a plastic sheath does not apply.
xymotic is offline
post #10 of 13 Old 05-17-2012
Senior Slacker
SlowButSteady's Avatar
Using a standalone LED lantern, or one wired to your boat's electric system, hanging in the foretriangle (about half-way up) is more visible in an anchorage. A masthead light can be seen a long way off (especially on a fifty-foot mast). However, anyone tooling around near-shore is much more likely to notice a light a bit lower down. This is particularly true on a misty/foggy night. At anchor, it's usually more important that other can see you from < 500 yards as opposed to 10 nm away. A lantern will also illuminate the foredeck a bit, making checking the anchor rode, et cetera, that much easier.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
Q: Standing rig wire size ulferlingsson Gear & Maintenance 1 06-11-2010 11:17 AM
wire size from battery to key switch ekenna Gear & Maintenance 12 03-26-2010 12:16 AM
Bonding wire size? sunfishin Electrical Systems 7 01-18-2009 10:25 AM
Lifeline wire size BreakingWind2 Gear & Maintenance 4 10-06-2008 09:15 PM
Windlass Wire Size 1970Columbia34 Gear & Maintenance 3 01-01-2007 09:05 AM
