Building a New battery system, need ALOT of help - Page 4 - SailNet Community
 3Likes
post #31 of 32 Old 05-25-2012
Stu Jackson's Avatar
Re: Building a New battery system, need ALOT of help
Originally Posted by nolasailor View Post
having to motor in and out of the marina,, about 2 miles,, i want to make sure the starter battery is only used for motor,,,, i want to keep it fool proof, would rather flip a switch to jump rather that have to remeber to flip back and forth all the time
There are a lot more complicated things on a boat than flipping a switch.
Run your alternator output to your house bank. Use the 1-2-B switch. ONLY when charging is present use B on the switch to charge your start bank. When charging is not present, use the switch in the position of your house bank. If you install the echo charger, you leave it on the house bank all the time.
What's so hard?
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #32 of 32 Old 05-27-2012
mitiempo's Avatar
Originally Posted by Stumble View Post
Nola,
Take the batteries back to SAMs, and head to Jefferson Battery. On Jefferson highway right across from the Lowes at the Orleans parish/Jefferson parish line. Their prices are much better than even SAMs, and they provide great service. They can also walk you through the process of selecting the proper batteries.
I just replaced mine, and walked out with 4 6v deep cycle batteries, 225ah each, for I think $350, including new jumper wires. The starting bank is actually a deep cycle set, but has more than enough CCA's to start my 44hp engine.
That is a pretty comparable price to the Deka/East Penn 6 volts under the Duracell name at Sam's.
Nola
If you are installing the Echo Charge soon, as I think you are, you have several options for switching.
1/2/both switch works - only problem is that whichever battery bank you select is powering everything.
2 simple on/off switches - start for engine and its ancillaries only and house for everything else. Downside is it doesn't allow for starting from the house bank. This is what I have.
A 1/2/both switch and a simple on/off switch. Use the on/off switch for the engine, use #1 on the 1/2/both switch for the house and wire from # 2 to the output of the on/off switch. This allows you to start from the house when the
1/2/both switch is in the "both" position and the on/off is "off." Diagram below from Bill Trayfors shows it as well as Echo Charge wiring. This gives you the most flexibility.
The install of both the Echo Charge and the Victron monitor are very easy.
I haven't heard anything bad about the Iota chargers - I installed a DLS-55 just last week.
Brian
mitiempo is offline
Building an FRP Holding Tank & System matt2 Gear & Maintenance 14 12-14-2009 08:48 PM
New Battery System sab30 Gear & Maintenance 27 09-05-2008 11:47 AM
Building A Battery Box Freesail99 Gear & Maintenance 18 12-20-2007 04:04 PM
battery system upgrade maestro Gear & Maintenance 3 03-01-2006 05:35 PM
Battery Recharge System OregonBob Gear & Maintenance 1 04-17-2005 09:24 PM
