Hooking 110 power cord to shore power? - Page 2 - SailNet Community
post #11 of 17 Old 05-29-2012
mitiempo's Avatar
Re: Hooking 110 power cord to shore power?
No. the boat side is correct but the 15 amp side is female not male.
This is the adaptor you need - female for the boat side and male 15 amp to plug into a standard extension cord.
Brian
mitiempo is offline
post #12 of 17 Old 05-29-2012
Originally Posted by dvuyxx View Post
Thanks for the responses but most of the answer-posts here have it backwards. I am sometimes docked at my in-laws house. They do not have a shorepower station on their dock and I want to hook up my shorepower system to their regular AC outlet.
Not to give you a hard time, but that's not what you said in your original post. You said you wanted to plug in a standard AC extension cord into a shore power system.
Catalina 34
chuck53 is offline
post #13 of 17 Old 05-29-2012
mitiempo's Avatar
He didn't say the shore power connection side was the boat side.
Brian
mitiempo is offline
post #14 of 17 Old 05-29-2012
A visit to the local hardware store to buy a 30 amp female , a 15 amp male plug and a foot of two of suitable wire to connect them should do the trick. Simple to make a collection of adapters for all occasions .Really useful is 30 amp male to dble duplex 15 amp box (long tail) for working on the dockside projects.
Capt Len is offline
post #15 of 17 Old 05-30-2012
Got it now. This is what you are asking for.
Marinco Shore Power Pigtail Adapter
However, powering the boat this way for an extended period isn't a great idea. Stopping over for a few hours maybe okay. The household plug does not lock in well, despite the screw, and the weight of your shore power cord has to be relieved or it is constantly trying to pull it out. I use this adapter over the winter on the hard to power up onboard battery chargers.
The other concern you'll have to deal with is your boats power draw. If she has 30 amp cables, you may overwhelm a 15 or even 20 amp household circuit. Smokey the Bear disapproves. Not all breakers will pop.
Our panel has an electronic switch, which can be set to the shore power input so it won't draw more than able. When we charge over the winter, we only have the chargers running. Nothing else and I stay there to supervise until done.
Jeanneau 54DS
Minnewaska is offline
post #16 of 17 Old 05-30-2012 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
Excellent. If Smokey The Bear approves then this is a good temp solution for short visits. I mostly want to run my charging system. I don't think that I will be drawing too much. Thanks.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #17 of 17 Old 06-02-2012
Here's what I use when my boat is in the yard: Furrion 15 Amp Male to 30 Amp Female Adapter
My Xantrex Link 2000 charger controller has the capability of limiting the current so I set it to 5 amps so that myself and everyone else on that receptacle don't throw the circuit breaker. I don't know that anything like this is built into the adapter so you need to make sure that you aren't drawing 30 amps over the 15 amp rated extension cord or through the 110 VAC receptacle.
DavidCReno is offline
Tags
ac current , extension cord , pigtail , shore power
shore power cord jaybird2719 News Feeds 2 04-11-2011 01:17 PM
Filthy Shore Power Cord Solution? Groven Gear & Maintenance 25 03-22-2010 09:48 PM
tip need for install of weatherboot on shore power cord tuccia Gear & Maintenance 10 09-06-2008 12:08 PM
Re: Shore power cord question NewsReader Mass Bay Sailors 0 01-30-2007 07:15 PM
