2nd Battery or Battery Booster - SailNet Community
 3Likes
post #1 of 18 Old 06-06-2012 Thread Starter
Hey everyone,
This is my first of probably many posts! I recently purchased my first vessel and have a boatload of questions. I am wondering if I should have a 2nd battery with a switch as a dedicated starting battery...just in case I drain my primary battery while overnighting on the lake? Or could I buy one of those battery booster pack/jumper boxes to keep on the boat? I am plugged into shore power at the dock for most of the week...so I could keep the booster charged up. I appreciate any and all ideas.
Thanks,
Bangbang
bangbang4086 is offline
post #2 of 18 Old 06-06-2012
Re: 2nd Battery or Battery Booster
What type of boat and how do you envision you'll be using it?
Carolyn Shearlock
CarolynShearlock is offline
post #3 of 18 Old 06-06-2012
Dirt Free
boatpoker's Avatar
What kind of boat, diesel or gas inboard ?
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #4 of 18 Old 06-07-2012 Thread Starter
It is a Hunter 27 with a 1 cylinder Yanmar inboard diesel. I primarily spend 1-2 nights on it a week. I daysail and spend the night at the dock. I am anxious to spend the night out on the lake, but not before I solve my battery query.
post #5 of 18 Old 06-07-2012
mitiempo's Avatar
I would install a second battery and keep it in reserve for engine starting/emergency.
Do you have a 1/2/both/off switch?
Brian
mitiempo is online now
post #6 of 18 Old 06-07-2012 Thread Starter
No I do not have a switch yet. This is why I was considering the booster box for cost effectiveness. I can buy one for about $100 bucks. If I go the 2nd battery route...then I am looking at the price of the battery, battery box, perko switch, etc....I am not afraid to spend the money, I just don't know if it is necessary? I am hoping the results of this post will sway me one way or another!
post #7 of 18 Old 06-07-2012
Tartan 27' owner
CalebD's Avatar
My $.02.
I've got a 27' Tartan and we use 2 group 31 batteries (upgraded from group 27) for our house and starting bank. We don't overnight enough so our old batteries lasted nearly 7 years, which is decent for battery life expectancy.
The more batteries with the more amp hours (AH) on it the better. Deep cycle lead acid batteries can be found at places other then West Marine, if you have time to shop around.
You won't regret adding another battery to your bank if you plan on doing significant overnightings.
Bring the battery booster along too. It might save your ass one day.
Everybody has one:
CalebD is online now
post #8 of 18 Old 06-07-2012
mitiempo's Avatar
What kind of switch do you currently have?
Even with one battery the ability to isolate the battery is needed - as well as proper fusing near the battery.
A 1/2/both/off switch can be purchased for around $30 or less.
A group 24 starting battery shouldn't be more than $50 or so.
A plastic battery box is under $10
A few cables and you're finished for about the same price as the booster box.
This gives you a second battery that will charge from the alternator or shore power charger that is always ready when needed. I would use the main battery for both house loads and engine starting, keeping the second battery for emergencies.
jrd22 likes this.
Brian
post #9 of 18 Old 06-08-2012
Yanmars usually have a compression release which will make it easier to start if you have a weak battery. Or if you have a hand crank. Thanks.
sstuller is offline
post #10 of 18 Old 06-08-2012 Thread Starter
Thanks to all for your replies. I think that I will be getting an extra battery in the near future.
Battery Chargers for Multiple Battery Banks btrayfors Electrical Systems 5 11-15-2009 11:57 AM
New Battery charger (unplugged) causes spark on battery post!! Northeaster Gear & Maintenance 15 11-17-2008 08:30 PM
Adding second battery; battery location zoom555 Gear & Maintenance 4 01-24-2008 08:46 PM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 12:43 AM
Starting Battery vs. House Battery GarrettK Gear & Maintenance 18 10-26-2004 10:58 AM
