Heat shrink connectors - SailNet Community
post #1 of 17 Old 07-04-2012 Thread Starter
minnow1193's Avatar
Are heat shrink connections watertight? Need to rewire lights on my trailer and want to make sure i don't have corrosion issues. I launch in saltwater. Thanks
Steve
minnow1193 is offline
post #2 of 17 Old 07-04-2012
heat shrink
The good adhesive lined ones are. Regular shrink tube will let in water and eventually fail.
bandaidmd is offline
post #3 of 17 Old 07-04-2012
Once known as Hartley18
Classic30's Avatar
Dock
Re: Heat shrink connectors
It does depends which ones you buy..
Look for the best quality (generally the most expensive) or smear cheaper ones with silicone if you're really concerned, but wrapping each connection with electrical tape good and tight will keep the water out for the length of time you'll have the trailer in the water.
Classic30 is offline
post #4 of 17 Old 07-04-2012 Thread Starter
minnow1193's Avatar
Was thinking i could put some grease/silicone in before i shrink it to help keep water out? Shouldn't affect the heat shrink process i think. ???
post #5 of 17 Old 07-04-2012
Senior Cruiser
sea_hunter's Avatar
Yes, if installed properly.
sea_hunter is offline
post #6 of 17 Old 07-04-2012
Senior Cruiser
sea_hunter's Avatar
Originally Posted by minnow1193:892703
was thinking i could put some grease/silicone in before i shrink it to help keep water out? Shouldn't affect the heat shrink process i think. ???
no.
post #7 of 17 Old 07-04-2012
mitiempo's Avatar
If you are using connectors with adhesive heat shrink do not use grease/silicone as it will not allow the adhesive to work properly.
Brian
mitiempo is offline
post #8 of 17 Old 07-05-2012 Thread Starter
minnow1193's Avatar
Good call. Thanks
post #9 of 17 Old 07-05-2012
If you get the kind that are adhesive-lined, such as these: FTZ Industries or these: Terminal Town's Electrical Connector Crimp and Seal/Crimp and Seal , for example: Yes - if properly applied.
Jim
SEMIJim is offline
post #10 of 17 Old 07-05-2012
heat shrink
I have tried the grease and silicone method with regular heat shrink, they both make a mess and only marginally improve there sealing. If its a job worth doing do it right the first time. West marine has the butt connectors with the adhesive lined shrink.
Dielectric grease or Heat shrink tubing andyjen Electrical Systems 21 07-17-2010 08:02 AM
Where can you get clear heat shrink tube? jarcher Gear & Maintenance 3 05-12-2010 04:38 PM
Ancor vs. 3M heat shrink adhesive connectors? turfguy Gear & Maintenance 39 05-04-2010 07:20 PM
Heat Shrink Line Splice 1970Columbia34 Gear & Maintenance 2 05-17-2007 12:43 PM
Marine Heat Shrink Tubing 1970Columbia34 Gear & Maintenance 4 01-18-2007 02:50 AM
