Battery Term fuses vs wired fuses - SailNet Community
 1Likes
  • 1 Post By SEMIJim
post #1 of 8 Old 07-19-2012 Thread Starter
One of None
deniseO30's Avatar
Those block fuses that use an stud mounting adapter right on the battery are very appealing. I'm wondering if they are OK rather then doing the "within 7" mounting of line fuses. (I'm about ready to install the bluesea ACR on my boat. )
My last project!
deniseO30 is offline
post #2 of 8 Old 07-19-2012
Re: Battery Term fuses vs wired fuses
Can't get much closer than right on the battery terminals, Denise I believe Blue Sea designed them for situations where mounting fuses or breakers separately, w/in the seven inch ABYC recommendation, was not practical. I've got two holders and three fuses on-order. If that isn't recommendation enough , Maine Sail uses them
Jim
deniseO30 likes this.
SEMIJim is offline
post #3 of 8 Old 07-19-2012 Thread Starter
One of None
deniseO30's Avatar
Thanks Jim! I was hoping so! Now I need to guess what size. the wire is #4 so I'm looking at 80 amps or less? None of the wires are over 20 ft, 2 cylinder kubota too. (need to do some amp draw readings soon)
My last project!
post #4 of 8 Old 07-19-2012
Denise,
The MRBF (terminal) fuses are one of only three types of fuses that you CAN connect directly to the house battery bank (the others being Type T and ANL).
They have a high enough AIC rating for this use. They are very convenient.
Keep in mind also that they can be neatly connected to a buss bar....sometimes this is desirable for physical layout reasons, or because you have loads connected to the buss bar which need different value fuses.
Bill
btrayfors is offline
post #5 of 8 Old 07-19-2012
Maine Sail's Avatar
They are great but do add about 2" in height to the battery and they just won't fit on LOTS of boats. I have been after Blue Sea for a while to put a 90 degree twist in the bar to make them side mount....... I still have to use LOTS of ANL or Class T fuses and just installed an ANL fuse on a bank today ebcause the MRBF was too tall..
The 7" rule is rarely able to be met but so long as that wire between the bank and fuse has no possible way of ever shorting then "as close as possible" is the next best thing. The only draw back to MRBF's are the height and that they only go to 300A, but the amp rating won't affect you.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #6 of 8 Old 07-19-2012
Maine Sail's Avatar
No need to guess..
______
post #7 of 8 Old 07-20-2012
No need to guess..
Well, yeah, ya maybe kinda do. Assuming an older boat, like ours, with existing cables: How is one to know what the "temperature rating of conductor insulation" is for their cables? I used the SWAG method for my installation, assuming that the rating on the existing cables is at least as high as the "economy" Seafit cable I bought to jumper the two negative terminals together. (And I had to dig for even that.) But it was only a guess.
Jim
SEMIJim is offline
post #8 of 8 Old 07-20-2012 Thread Starter
One of None
deniseO30's Avatar
Well the good news is my new Norcold unit is running off the house bank. Left the boat on the dock with it running want to see how low the bank gets from about 7 last night until about 11 today (7/20)
MS yes .. no need to guess, I do just need to ck the amp draw on the starter.
My last project!
question about fuses Fitz87 Electrical Systems 10 01-12-2011 12:53 PM
Blade or Glass fuses?? SanDiegoChip Electrical Systems 12 10-19-2010 09:56 AM
Fuses for the charging circuit rocinante33 Gear & Maintenance 5 06-17-2009 10:16 AM
The Value of Circuit Breakers and Fuses Chris Brignoli Gear and Maintenance Articles 0 03-24-2003 07:00 PM
breakers and fuses and amps oh my jbarros Gear & Maintenance 6 09-06-2002 11:17 AM
