Redoing shore power correctly - Page 3 - SailNet Community
 4Likes
post #21 of 32 Old 08-16-2012
Re: Redoing shore power correctly
Do not connect your safety grounds through that chincy ground screw. You need to provide another connection point within the junction box and pigtail another wire to that point. You can safely use 14 gauge wire for this.
Eric
olson34 likes this.
fairbank56 is offline
post #22 of 32 Old 08-16-2012
Re: Haven't blow up yet!
Originally Posted by jaschrumpf View Post
Went to the boat this weekend and my Blue Sea main+6 panel wasn't in yet, so I picked up the main breaker to put in between the shore power plug and where the panel will be (it's about a 15 foot run). Pulled out the old Romex house wire and ran nice new Triplex 10 gauge wire from the shore plug to the corner where I put the main breaker. Used all crimp wire ends everywhere. Flipped the switch and the little green Power light came on. No smoke or sparks!
Can't wait to get the main panel and outlets in.
Romex is solid wire....Boats Move....U need to use Strandred wire...Tinned is best...next best is Copper.....Don't use Aluminum wire in a boat.
As for the best saftey for AC is an Isolation transformer.
Isolation transformer example
ParadiseParrot is offline
post #23 of 32 Old 08-16-2012 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
Eric
That's what I need: a pigtail. I can join the three grounds to a screw in the back of the junction box. Luckily I bought a nice big one (4" x 4" x 4"), so there's plenty of room inside.
Thanks for the tip. Shoulda thought of that one.
S/V Free Spirit
Monrovia, MD
jaschrumpf is offline
post #24 of 32 Old 08-16-2012
mitiempo's Avatar
I would think 2 10 awg ring connectors stacked would make a better connection than any 14 awg run. The incoming AC source should be 10 awg minimum for 30 amp service.
As far as a pigtail, it does introduce more connections than necessary.
Brian
mitiempo is offline
post #25 of 32 Old 08-16-2012 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
In this case it would introduce one extra connection. I wouldn't use 14 awg wire, I'd use the 10 awg that I used for the main run. But it sure would be a lot easier to make the connection.
The only possible way to get all the ring terminals on the little tiny screw is to bend them so they "stand up." Not enough room in there to lay 'em down as usual.
I just can't figure out that design. The four hot and neutral terminals (two each) are big screws that have exactly one wire going to each one, while the ground that has to have three wires attached (one of them being a wire used by the main switch itself) is a puny little thing.
Seems dumb to me.
S/V Free Spirit
Monrovia, MD
post #26 of 32 Old 08-16-2012
mitiempo's Avatar
The three connections should fit if they are going off in different directions.
The other option is to drill and countersink for a #10 machine screw and use that.
Brian
mitiempo is offline
post #27 of 32 Old 08-16-2012
You can use 14 for the short pigtail wire because as per ABYC that size single conductor wire not bundled, sheathed or in conduit and outside of engine compartment can safely handle 35 amps of current which is more than the shore power breaker rating. If 10 gauge is no problem, then go for it but the smaller wire can be used to make it easier (smaller lug, more flexible). I agree the design for the ground connection on that panel is a joke.
Eric
post #28 of 32 Old 08-18-2012 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
What the instructions from Blue Seas didn't say
Namely, any mention of grounding the main AC panel to the common DC ground, i.e., the engine block. The schematic clearly shows only the ground from the AC source and then the individual grounds from each device.
I did ground the distribution panel to the engine out of respect for the opinion of many here who said it was a safety issue. I do not yet have a galvanic isolator, so I guess my question at this point is since Blue Sea didn't mention an engine ground as being necessary and I don't have the isolator, is it better for my electroactive metals and nearby boats to not have the engine ground?
S/V Free Spirit
Monrovia, MD
post #29 of 32 Old 08-18-2012
mitiempo's Avatar
Connecting the AC ground to the DC ground bus is a requirement of ABYC. It does introduce corrosion issues that are solved with the installation of a galvanic isolator. Both the AC/DC connection and the galvanic isolator should be added at the same time.
Brian
mitiempo is offline
post #30 of 32 Old 08-18-2012 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
It's interesting that connecting the AC ground to the DC common bus is an ABYC requirement, yet Blue Sea doesn't mention or show it on the schematic.
Galvanic isolators are referred to as being "inexpensive," yet the ones I've seen on line average around $200 or so. Does that sound right, and "inexpensive" is a very relative term, or am I looking at the wrong thing?
S/V Free Spirit
Monrovia, MD
Hooking 110 power cord to shore power? dvuyxx Electrical Systems 16 06-02-2012 09:35 AM
Shore Power H and E Gear & Maintenance 3 10-02-2011 11:42 AM
Non-US Shore Power coyotejack Cruising & Liveaboard Forum 6 03-21-2011 10:37 AM
shore power with out shore power marcusn Gear & Maintenance 33 06-20-2008 03:55 PM
shore power NewsReader Mass Bay Sailors 0 02-01-2007 10:15 AM
