Charge Controller and batteries for solar panel - SailNet Community
post #1 of 4 Old 08-13-2012 Thread Starter
Send a message via AIM to jkzdad Send a message via Yahoo to jkzdad
I am installing 4 new Kyocera 140kw panels on my 46" Beneteau. Going with either a Outback or Morningstar 60amp controller. Looking for tips on installation. Do I need breakers and where do they get installed? Also what is best position for controller? Closer to the panels or the battery bank?
Also putting in new battery bank. 4 4D AGM batteries for the house. Any suggestions on which batteries to go with?
jkzdad is offline
post #2 of 4 Old 08-13-2012
Re: Charge Controller and batteries for solar panel
Breaker or fuse should be located near the battery bank. If you're going to use a breaker, be sure it has a high enough AIS rating...at least 5,000 amps. I believe only the new, special Blue Sea Systems breakers have this.
If you're going to use a fuse, make it an ANL or a MRBF, located near the battery bank.
The Concorde Lifeline GPL-4DL is a good AGM battery. Hope you're upgrading your charging capability. These AGMs can easily take five times their AH rating when 50% discharged, i.e., the 210AH GPL-4DL can take 1,000 amps or more for a few minutes before dialing back. Four of these could potentially take 4,000 charging amps!! Obviously, this isn't possible, but to get the best from your AGM battery bank you'll want to beef up the onboard charging capacity as much as you reasonably can.
Bill
btrayfors is offline
post #3 of 4 Old 08-13-2012
Senior Cruiser
sea_hunter's Avatar
Outback. Breaker after panels and before charge controller; after charge controller, before batteries. Close to cc. (recommended by manufacturers) You can contact Outback directly (great tech support) or wholesalesolardotcom also the best pricing, support and aftersales service for both products you're looking. Been using them for years.
sea_hunter is offline
post #4 of 4 Old 08-13-2012
Senior Cruiser
sea_hunter's Avatar
Forget AGMs, go for the best bang for the buck; flooded. More amphrs per size and last longer as well as being able to equalize.
Solar Charge Controller and Battery Hookup sailtobike SailNet FAQ 9 06-18-2011 05:20 PM
Charge Controller for wind and solar cvsheppard Electrical Systems 1 01-04-2011 04:45 AM
need help choosing a charge controller for solar and wind newcruiserP10M Electrical Systems 1 09-23-2010 01:36 PM
Solar charge controller Jotun Gear & Maintenance 10 04-13-2007 02:22 PM
Best Solar Charge Controller? mmccoy Gear & Maintenance 1 07-28-2004 11:46 PM
