Old 08-19-2012
L124C's Avatar
L124C is on a distinguished road
Mystery wire!
I've noticed this blue wire wrapped in with the wiring harness that leads to the starter of my Yanmar 2GM20. One end female, the other male, neither connected to anything! Didn't think to check it for continuity (DUH!), but I'm assuming it's the same wire. It's approximately a foot long. There IS a spare connection on the wiring schematic, but this ain't it! I know it's not a lot to work with, but I would be interested in your thoughts?
  #2
Old 08-19-2012
sailak's Avatar
Crealock 37
sailak is on a distinguished road
Re: Mystery wire!
I do believe I have that same blue wire in the harness for my 3GM30F. Possibly the wiring harness is used in an application where that wire is needed?
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
  #3
Old 08-19-2012
ParadiseParrot is on a distinguished road
Re: Mystery wire!
Boat Wiring
Should be a sender wire if color is correct
  #4
Old 08-20-2012
L124C's Avatar
Re: Mystery wire!
Originally Posted by ParadiseParrot View Post
Boat Wiring
No. My oil sender wire is yellow/white and temp sender is white/blue.
  #5
Old 08-20-2012
L124C's Avatar
Re: Mystery wire!
Is yours open on both ends?
  #6
Old 08-20-2012
ldog68's Avatar
ldog68 is on a distinguished road
I am not familiar with that harness per se..... But in the industry i work in, lots of harnesses have extra wires depending on the options the equipment may or may not have... Just my $0.02
Catalina 27 under refit.
Catalina 22 and O'day 14 Javelin to play with while working on the 27!
  #7
Old 08-20-2012
HPLou is on a distinguished road
Send a message via AIM to HPLou
Re: Mystery wire!
I noticed the same for my Yanmar 2GM20 a few years back. After reading the service manual, I learned it's an unused wire for the 2GM20 and 3GM30. It makes note that the use for that blue wire would be for the 1GM10.
  #8
Old 08-20-2012
sailak's Avatar
Crealock 37
Re: Mystery wire!
Yes. Has a male connector on the end "toward" the engine.
Dale
S/V Elnora
You may post attachments
You may edit your posts
Help me ID mystery part? chartscharts Gear & Maintenance 8 09-19-2011 05:55 PM
Indentifying Mystery Hardware (Mystery to me anyway) :) krozet Gear & Maintenance 7 04-19-2010 04:26 PM
Mystery - pls help perrygv Sailboat Design and Construction 10 10-06-2008 11:27 AM
SEO by vBSEO 3.6.1
