Leaving Dead battery on shore power charger - Page 2 - SailNet Community
 2Likes
post #11 of 15 Old 02-12-2013
Go Cowboys
jobberone's Avatar
Re: Leaving Dead battery on shore power charger
I thought the newer battery chargers would stop charging when full. Is that true? I realize the battery is dead. Is there an automatic shutoff on the newer battery chargers when resistance is high?
jobberone is offline
post #12 of 15 Old 02-12-2013
You can't presume anything about the newer "smart" chargers. Many will not turn on if the battery is below 10.5 volts, or a similar value. The only way to be sure of how your charger works, is to check the manual for your charger.
hellosailor is offline
post #13 of 15 Old 02-12-2013
Brewgyver's Avatar
Yes, a good mantra to go through life in this highly tecnological age:
When in doubt, read the instructions.
And a good truism to combat complacency:
Assumption is the mother of all #%@k-ups.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #14 of 15 Old 02-12-2013
Maine Sail's Avatar
Some dumb chargers turn off but most of the "smarter" ones don't turn off they simply maintain a voltage. It requires current to maintain a float voltage so most of them just stay on at a very, very low current.. Some are not as accurate as others and "pulse" the power supply on/off so as not to over shoot the voltage and others have the ability to pump out 0.1A for weeks on end if needed.
As for the OP I would not advise leaving a dead battery on-charge unattended.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #15 of 15 Old 02-12-2013
chef2sail's Avatar
Originally Posted by Rockter View Post
A dead battery has a low internal resistance, and if it is truly dead, likely to stay with a low resistance. If so, it will stay warm on charging, it will have a high current draw, and just boil off the electrolyte.
I would not leave it unattended long-term.
Stay with it the first day and night, and check it for temperature and current draw.
If it seems to be tolerating it, it will probably be OK.
Personally, I don't use shore chargers. I have never liked the idea of the electrical system being live while unattended.
So you dont beleive in plugging in electric cars to charge when inattended?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
Tags
batteries , battery charger , shore power
Shore power vs battery while at slip sailingcal21 Electrical Systems 13 03-28-2012 09:57 PM
Shore Power went dead help! newcruiserP10M Electrical Systems 6 12-06-2010 12:49 PM
shore power battery charger - need recommendation pegasus1457 Electrical Systems 7 10-20-2009 06:13 PM
shore power battery charger samhamt Gear & Maintenance 12 06-22-2009 05:53 PM
shore power battery charger samhamt Gear & Maintenance 1 06-21-2009 02:53 PM
