AC power switch - Page 2 - SailNet Community
post #11 of 15 Old 09-21-2012 Thread Starter
s/v Black Prince
stiffwind's Avatar
Re: AC power switch
Another question comes to mind based upon the comments that the wiring I described was faulty for not using the AC Master Switch as the starting point to turn on shore power...if the shore power to the boat is now hot as soon as I plug into shore, I would imagine that some marine electrical manual or standard would be violated because it would seem potentially dangerous to be handling shore power cord plugs while the system was hot. In other words, with his yard's set up, each time I disconnect shore power plugs the line is hot instead of doing that hook up while the line is off at my AC panel?
Does that make sense?
Been sailing all day with Dad, and I need a drink?
stiffwind is offline
post #12 of 15 Old 09-23-2012
Stu Jackson's Avatar
Re: AC power switch
A little confusing. Did you not get a manual with the inverter? Does it not have wiring diagrams in it?
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #13 of 15 Old 09-24-2012
mitiempo's Avatar
Re: AC power switch
Shorepower should go to a double pole breaker within 10' of the inlet regardless of whether there is an inverter/charger or not.
Brian
mitiempo is offline
post #14 of 15 Old 09-25-2012 Thread Starter
s/v Black Prince
stiffwind's Avatar
Re: AC power switch
Brian,
What is the authority for your statement. Is it required by ABYS? or some electrical bible?
post #15 of 15 Old 09-25-2012
mitiempo's Avatar
Re: AC power switch
Both ABYC E-11 and common sense.
here is the relevant section:
Brian
mitiempo is offline
Dauphin Island power cut when sailboat hits power line - Press-Register - al.com (blo NewsReader News Feeds 0 08-28-2012 05:00 PM
Hooking 110 power cord to shore power? dvuyxx Electrical Systems 16 06-02-2012 10:35 AM
Perko 4-way switch Omatako Electrical Systems 39 06-11-2011 11:03 PM
1 all 2 switch gone bad? ekenna Electrical Systems 2 01-04-2010 06:45 PM
mystery switch teodoro50 General Discussion (sailing related) 45 06-01-2008 01:49 PM
