Wiring diagram house/starter bank needed - SailNet Community
 1Likes
post #1 of 14 Old 09-21-2012 Thread Starter
Hello Everyone,
Would anyone have a wiring diagram for the following setup?
- 1 starter battery 12V
- 1 battery 12V for the windlass
- 6 deep cycle battery 6V to form a single 12V house bank (this has already been wired)
- Xantrex inverter/charger TR1512 (powered from shorepower or a Honda 2000i generator, this connection to the housebank is also done and seems to work fine)
- 38HP diesel engine, alternator running through a Heart Interface Incharge 3 stage alternator regulator
- an electric switch to disconnect the alternator
I assume what is recommended is a 1-2-both switch to isolate the house bank from the starter battery so the engine could be started with either the starter battery, house bank, or both.
Thanks,
Dan
Dan1234 is offline
post #2 of 14 Old 09-22-2012 Thread Starter
Wiring diagram house/starter bank; critique needed
Is this gonna work?
Dan1234 is offline
post #3 of 14 Old 09-22-2012
Maine Sail's Avatar
Re: Wiring diagram house/starter bank needed
Originally Posted by Dan1234 View Post
Hello Everyone,
Thanks,
Dan
I would simply lose the windlass battery and run the windlass and other loads off the house bank. If you do that there are many possible ways to wire it. It can be done, with three banks, but I'd like to hear your reasoning behind why you want to have to manage and wire up three banks..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 14 Old 09-23-2012
Stu Jackson's Avatar
I agree, no need for three banks, why complicate matters.
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: Basic Battery Wiring Diagrams
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
1/BOTH/2/OFF Switches Thoughts & Musings - SailboatOwners.com
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 14 Old 09-23-2012
ebs001's Avatar
I am of the opinion that a windlass should be connected to the start battery rather than the house bank. The start battery should be one rated in CCA and is designed to provide a large current draw of short duration (engine starting and windlass loads) as opposed to deep cycle batteries which are designed for low current draws of long duration (lighting and electronics). Other than that I agree with you that only 2 banks are required.
ebs001 is offline
post #6 of 14 Old 09-23-2012
Maine Sail's Avatar
Windlasses are anything but "short duration" compared to starting an engine. Starting batteries are rated for 30 seconds duration. If the motor is running every time you run the windlass then it can be okay but a sufficiently sized house bank, for a boat that has a windlass, will nearly always maintain a higher voltage during anchor raising than a single start battery. Higher voltages at the windallass motor mean a happier windlass. CCA and MCA ratings are for 30 seconds and allow the battery to drop to 7.2 volts.
As an example I just re-wired a bow thruster the owner was having loads of issues with. The thruster was wired to the starting battery. I simply moved it to his bank of four 6V batteries and he now maintains over 11.7V when using the thruster vs. just 8 volts off the start battery. It now actually moves the bow of his boat...
The idea that deep cycle batteries cant power a windlass and support a decent voltage is not the case with a sufficient house bank. They usually do far better than a starting battery unless the start battery is massive.
I worked on a boat last Wednesday that had four group 31 batteries and as measured was delivering over 3200 CCA on that bank. At 70f that is well over 4000 CA. That banks powers that windlass and the electric winches like there is no tomorrow. The start battery in contrast was delivering just 530CCA or about 700 CA at 70F...
______
post #7 of 14 Old 09-27-2012
asdf38's Avatar
I can understand the advantages of eliminating a windlass battery. But I can also see the motivation to avoid running huge wires across the entire boat (12V is pretty bad for power delivery over distance).
What about a windlass battery charged via a current limiting echo charger? It keeps the forward battery charged but the limited unidirectional current means you can get away with smaller wires (properly fused at the forward windlass battery). The disadvantage is that the windlass would only have access to the power in the forward battery, if it died, so would the windlass.
asdf38 is offline
post #8 of 14 Old 09-27-2012
For an EchoCharge to maintain a separate windlass battery properly, you'd still have to use pretty large size wires to avoid excessive voltage drop over long runs. It's do-able, though.
I chose a different route: I have two T-105 Trojans under my V-berth forward which power the windlass. These are charged by an Iota DLS-55/IQ4 battery charger also located in the forward cabin. The charger is powered either from shore current or from my onboard 3.5KW AC generator. In an emergency, it could also be powered from my Victron Multi-Plus 2500 watt inverter, drawing current from the house batteries (six T-105s).
Even without charging, I think the T-105 pair have enough oomph to operate the windlass (Lewmar Concept 2) for at least 5-6 anchoring cycles -- both down and up.
This system has worked quite well for many years now. I chose this solution because I like very often to come to anchor under sail, and to sail off the anchor without the engine running. As MaineSail says, the house batteries do a very good job of powering the windlass without the need to start the engine.
Bill
btrayfors is offline
post #9 of 14 Old 09-27-2012
asdf38's Avatar
Deep cycles can supply cranking amps as well and the difference isn't that big. For comparison Deka (Sams club duracell, some West Marine batteries) spec their G27 starter/dual/deep-cycle battery's at 840/650/575 CCA respectively. So the deep cycle puts out only 32% less cranking amps than the dedicated starter (and interestingly only about 10% less than the dual purpose).
So while the deep cycle can start all day long with no damage, the starter will die quickly if deep cycled. I think some people cling to a firm division between start and deep cycles that isn't justified by the numbers. This is why I have a deep cycle reserve/start battery in my boat.
http://www.dekabatteries.com/assets/base/0194.pdf
asdf38 is offline
post #10 of 14 Old 09-27-2012
mitiempo's Avatar
While the house bank is normally composed of deep cycle batteries - golf carts for instance - because of the bank size it most often would have more cranking ability than a single starter battery.
Brian
mitiempo is offline
Need wiring diagram Cyane Sailboat Design and Construction 3 08-05-2012 01:53 PM
Wiring diagram needed old-sailer C & C 1 05-28-2012 07:42 AM
Sanity check needed on short-term house bank configuration rhumbunctious Gear & Maintenance 13 12-02-2010 07:14 PM
Wiring Diagram Needed-1 Engine, 2 Switches, 3 Batteries Compujedi Electrical Systems 19 09-24-2010 10:48 PM
Yanmar wiring diagram mikethecapt Gear & Maintenance 7 11-22-2007 07:58 PM
