What size AC breaker? - SailNet Community
post #1 of 21 Old 09-25-2012 Thread Starter
My new to me boat has 30amp shorepower which is wired to 2 15amp breakers. These are household breakers that are located on the cabin deck inside of a standard home metal box! I have a Blue Sea 120v ac panel with burned out 30amp dual breakers. I would like to hook up the Blue Sea and get rid of the household setup. My question is should I go with the original 30amp dual breakers or go with a 15 or 20amp dual breaker to power the onboard electrics. Heater, lights etc when docked? Thank you.
Froggy is offline
post #2 of 21 Old 09-25-2012
poopdeckpappy's Avatar
Mine has dual 15 on a 30 amp sp
Not being a electrical expert but, I would want to know how or why dual 30 ( 60amp house main ) burned out first
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #3 of 21 Old 09-26-2012
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
Re: What size AC breaker?
A breaker only protects the circuits beyond the breaker. Thus, if the first breaker in line from the shore power inlet is at the panel any short in the wire from the "house entrance" (where the shore power is plugged into the boat) and the panel will not be protected and could result in a fire. You should have a 30 amp breaker right inside the boat at the house entrance. It should be in a waterproof box.
To see what bad shore power can do at the "house entrance" see Sailing - Reboot (USA 60493): I never saw a thing
If you do not need to leave the boat plugged in to charge the batteries it is a good idea to turn off the power at the marina pedestal and unplug the wire when you leave the boat. Many marinas have stray electrical currents that will eat your zincs alive. By unplugging the boat you reduce these stray currents and your zincs will last a whole lot longer.
CAPT Roger J. Jones USN (ret.)
Sailboat Reboot
411 Walnut Street, #9700, Green Cove Springs, FL 32043-3443
Reboot's Agent's Email:
Web Site:
Blogging:
Twitter @Sailboat_Reboot
svzephyr44 is offline
post #4 of 21 Old 09-26-2012
Newbie
DannyboyUpstate's Avatar
The maximum breaker size is bound by the type and size of the conductor going to the load.
DannyboyUpstate is offline
post #5 of 21 Old 09-26-2012
It is protected by the breaker in the shore based distribution panel that feeds the shore power receptacle.
Eric
fairbank56 is offline
post #6 of 21 Old 09-26-2012
Capt. Gary Randall's Avatar
Hello there, I don't understand why you have a dual breaker on 120 V. AC 30 amp. This circuit requires only one single 30 amp breaker.you should have a black wire that delivers current, a white wire which is neutral, and a green wire which is ground. The circuit breaker only protects the black wire which is commonly called a hot lead. Normally when you have a double breaker you're dealing with 220 ac which in that case there are four wires. You really need to have someone who is familiar with marine wiring help you with this. You don't know what someone else has done. Attempting to do this yourself without experience, could cause damage to your boat or you. Or someone might be swimming close to your boat..... this is something I really believe you should get help with.....captg
[SIGPIC] The only difference between an ordeal and a adventure is your attitude!
Capt. Gary Randall is offline
post #7 of 21 Old 09-26-2012
A dual simultaneous trip circuit breaker is an ABYC requirement for 120vac single phase shore power feed.
Eric
post #8 of 21 Old 09-26-2012
Maine Sail's Avatar
On boats it is an ABYC requirement to break both white/neutral and black/hot even on a single phase 120V circuit. This is why main breakers for AC on boats are doubles. On branch circuits after the main AC breaker only the black/hot needs to be broken....
Also if the wire run between the AC inlet and the main AC panel breaker is longer than 10' (wire length not as the crow flies) there should be an additional main breaker at the entrance point or close to it.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #9 of 21 Old 09-26-2012
Only if the boat is equipped with a reverse polarity indicator or isolation transformer. If not, the branch circuit breakers must be douple pole.
Eric
post #10 of 21 Old 09-26-2012
I'm used to dealing with systems that have polarity protection, however it sounds like this gentleman needs some help. Especially if he has household wiring or distribution. That in itself tells me that it would be very difficult for him to have ground protection in a household distribution panel. I think he needs professional help, maybe you can help him. Eric
Breaker for AC mitiempo Electrical Systems 6 04-20-2012 05:25 PM
Testing a breaker. L124C Electrical Systems 28 03-09-2011 11:58 PM
breaker box QuickMick Gear & Maintenance 4 03-26-2010 03:06 PM
breaker box QuickMick Gear & Maintenance 18 12-09-2009 09:03 AM
Tie Breaker km2x Racing 2 07-12-2006 11:35 PM
