Is this bilge pump wiring as bad as I think? - Page 3 - SailNet Community
 1Likes
post #21 of 25 Old 10-16-2012 Thread Starter
GrahamO's Avatar
Re: Is this bilge pump wiring as bad as I think?
Originally Posted by denverd0n View Post
Any particular type or brand of self-amalgamating tape that you prefer?
It has been a while since I worked offshore but I think we used 3M (Scotch) then. We used to stagger the connections, twist wires together (crimps create a weak point when a lot of flexing is likely, NEVER solder), insulate each wire with adhesive heat shrink, coat the whole joint with a VERY messy goop similar to liquid electrical tape, and then use self amalgamating tape. This was good for 10,000' of seawater if done right so it should work in a bilge...... The liquid tape was to get all the air out of the join to make it pressure tolerant - not required for bilge use.
Interesting side tips: When connecting to terminal strips we never used heat shrink on terminals because they could get contaminated with salt water and then corrode through unseen. Also we never used ring terminals, always spades. This is counter-intuitive but it is MUCH easier to find a loose connection where the wire has actually fallen off than an intermittent open circuit caused by a loose ring terminal. If we could only get ring terminals we would snip them open before use.
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #22 of 25 Old 10-17-2012
Freedom 39
FarCry's Avatar
Originally Posted by L124C View Post
You didn't mention if the strip is on the Pos or Neg side of the circuit (a pictures worth a thousand words BTW). Sounds like in an emergency situation it could be submerged, (potentially leading to a bigger emergency where the entire boat is submerged!). If it is positive, would this short it out (I don't know, had never thought about it)?
In any case, IMO, cutting crimping/soldering and waterproofing wires is easy enough. I want all wiring related to my bilge sealed. Bilge pumps and switches can be problematic enough, even when properly wired. No sense complicating the issue!
Regarding a second pump: I installed a diaphragm pump as a bilge maintenance pump. Worked out well. Search for my thread here if interested.
I used a dual type terminal strip that had continuity between the two lugs much like this IDEAL INDUSTRIES, INC. - Terminal Strip (.625 Spacing)
There is both positive and negative wiring (labeled) on the strip. I had it mounted just under the highest part of the sole (there is a 6" elevated area at the base of the companionway stairs that is above most of the sole) and above the highest point of the batteries. If the batteries are submerged Far Cry would have about 4' of water in her bilge, water over most of her sole and probably hundreds of gallons of water inside. At that point I believe I would have far greater concerns than whether the terminal strip was submerged. This system was in place for about 6 years and made trouble shooting and replacing the float switch very easy. I resprayed the terminal strip after installing the new conductors. There was no visible corrosion and it was still shiny. If one had to respray it every time a pump or switch failed, I could live with that. It may not work in other situations but I feel it was the best solution for me.
I do not have a simple way to measure humidity above and below the sole nor do I really care. According to the NWS this time of year the humidity is in the 90% range so I doubt another possible 10% will make much of a difference.
I no longer own Far Cry or I'd be glad to take a photo to post if there was further confusion. I do appreciate that it does not meet ABYC standards. If I had the smallest safety concern, I wouldn't have done it.
FarCry is offline
post #23 of 25 Old 11-08-2012
I've had one of the Ultra switches for about 16 years with great results. I never thought much about it until last month, hanging upside-down in a friend's bilge in rough seas trying to fix a flapper that was getting stuck in the "pump" position every hour or so.
For a bilge alarm - a completely independent battery-operated one is a good idea. I picked up a 9V one a long time ago - the battery/buzzer goes anywhere and the float I just epoxied to the side of the bilge. Would be easy enough to make one up. Just an extra layer of safety in case my neighbor accidentally kicks my shore power cord and a hose rots out at the same time and no one notices it pumping for three or four days. (I'm not paranoid if it could really happen, right?)
AlanF is offline
post #24 of 25 Old 12-05-2012
Originally Posted by GrahamO View Post
It has been a while since I worked offshore but I think we used 3M (Scotch) then. We used to stagger the connections, twist wires together (crimps create a weak point when a lot of flexing is likely, NEVER solder), insulate each wire with adhesive heat shrink, coat the whole joint with a VERY messy goop similar to liquid electrical tape, and then use self amalgamating tape. This was good for 10,000' of seawater if done right so it should work in a bilge...... The liquid tape was to get all the air out of t.
we use to use scotch kote on underwater cutting rigs using broco rods we would have welding cables bolted togther scotch kote them then wrap them in rubber tape scotch kote them again and wrap them in electrical tape
at first i was really scared about getting shocked but it never happened
southern cross
ct-34
Southron Spirit is offline
post #25 of 25 Old 12-06-2012 Thread Starter
GrahamO's Avatar
Scotch Kote - that's the stuff!
Broco rods takes me back. We used to use them to cut 1/2" plate on deck - a VERY interesting experience..... That was before the days when going to the bathroom required a Job Safety Analysis.
Graham and Janaki
Bristol 38.8
GrahamO is offline
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 07:26 PM
Rule Bilge Pump wiring tip Electrical Systems 7 02-13-2011 04:33 AM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
rule bilge pump wiring duffyM General Discussion (sailing related) 6 05-27-2008 09:59 AM
