Simple electrical panel - Page 2 - SailNet Community
post #11 of 13 Old 10-19-2012
Sumner10's Avatar
Location: Utah (House & Macgregor 26 Classic) -- Florida (Endeavour 37)
Re: Simple electrical panel
Thanks. On the labels are they just stuck onto the wood? We finally got a label gun, but I was thinking that I needed to put the labels on something smoother than wood to be permanent.
I use interior/exterior gloss polyurethane on everything and I guess maybe 3 coats, sand flat and another 2-3 coats would give a good surface for the labels???
Have you mounted the panel in the boat yet? If so Pics?
Sum
Our 37 Endeavour --- Our 26 MacGregor --- Trips With Both
Sumner10 is offline
post #12 of 13 Old 10-19-2012
asdf38's Avatar
Yeah the labels are just stuck to the wood over a single coat of stain (I didn't want it darker). However it's in a place that can't accidentally be hit or brushed very easily otherwise I might have given this situation more thought. After one season no problem. These are the bluesea labels I linked earlier.
But it certainly sounds like what you're suggesting would do it. If you were concerned about them falling off you could epoxy them down. I don't mind knowing that I could change them if I wanted.
I'd love to do a custom engine panel this year although it's hard to justify it has a priority when I have leaks and deck issues. But if I did I was considering designing a panel to be professionally printed. The engine panel is different of course because it's outdoors.
Here it is in the boat next to my less successful attempt to adhere cables with hotglue (I think the glue melted when the cabin got hot).
asdf38 is offline
post #13 of 13 Old 10-19-2012
Sumner10's Avatar
Thanks. The panel....
....looks good mounted there and I wouldn't of noticed the cables if you wouldn't of mentioned them,
Sum
Sumner10 is offline
New electrical panel saillife Electronics 7 07-21-2011 12:15 AM
Looking for a low windage, low maintenance, simple electrical system solution chrisncate Gear & Maintenance 174 04-25-2011 12:14 PM
Simple electrical system question radioguy Electrical Systems 9 08-15-2010 08:25 PM
Electrical Panel bob1956 Irwin 2 09-21-2006 05:38 AM
Electrical Panel whathree General Discussion (sailing related) 2 05-24-2006 10:33 AM
