Simple 15A Shore Power In Small Boat (Looking to install in-line 15A AC Breaker) - Page 2 - SailNet Community
 2Likes
post #11 of 15 Old 11-05-2012
Re: Simple 15A Shore Power In Small Boat (Looking to install in-line 15A AC Breaker)
I'm sure you'll get feedback from some that are more familiar with ABYC requirements for permanently installing 110v power aboard. I've not seen it done without a mounted hull receptacle and a breaker panel. You bring 30amp to the panel and install a 15a breaker that runs to the internal receptacle.
Do this all correctly. Electrical fires are the number one cause of boat fires. More than engines, fuel and galleys.
chef2sail and boatpoker like this.
Jeanneau 54DS
Minnewaska is offline
post #12 of 15 Old 11-30-2012
I'd be interested in hearing about the proper way to do this as well.
What are some sources for learning how to properly wire AC on a small boat?
Dubbinchris is offline
post #13 of 15 Old 11-30-2012
Dirt Free
boatpoker's Avatar
I have found much of this thread difficut to follow but going from a 30amp pedestal through an 15amp adatpter to a 30amp boat is contrary to NEC, NFPA303 and ABYC E-11.
By doing this you are turning the 15amp cord into a 15amp fuse. If the breaker on your boat is 30amp and you turn things on totaling more than 15amps ... things will melt before a breaker trips.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #14 of 15 Old 11-30-2012
" but going from a 30amp pedestal through an 15amp adatpter to a 30amp boat is "
Is not what the topic is about, boatpoker.
Try again, from the top, or from the thread title. The ENTIRE BOAT is SIZED FOR 15A. There's no mention of a 30A breaker or load on the boat. The question is simply how to connect a 30A shorepower adapter, to a 15A maximum load. (Boat, cable, breaker, the whole shebang.)
No danger there.
hellosailor is offline
post #15 of 15 Old 11-30-2012
Dirt Free
boatpoker's Avatar
No danger there.
Yeah I got that but some of the other posts seemed to go in a different direction.
I can do that
- wg
Second shore power line beanctr56 Gear & Maintenance 13 09-15-2011 10:35 AM
Help: Simple Shore Power System YeahJohn Electrical Systems 52 01-26-2011 11:10 AM
tip need for install of weatherboot on shore power cord tuccia Gear & Maintenance 10 09-06-2008 01:08 PM
Shore Power for a small boat? 75R20 Gear & Maintenance 3 06-21-2008 08:53 PM
Shore power problem! Burned ground wire at main breaker JohnDrake Gear & Maintenance 2 08-20-2002 06:08 AM
