Faulty Starboard Running Light - SailNet Community
 2Likes
post #1 of 11 Old 12-08-2012 Thread Starter
halsask
I have just purchased a 1982 C&C34 and have found that the starboard running light does not work. The port one works fine. Have tried changing the bulb, no help. I don't even know where to start looking. Would there be somewhere I could get a wiring diagram or schematic. Help Please.
halsask is offline
post #2 of 11 Old 12-08-2012
Re: Faulty Starboard Running Light
The first place to look would be corrosion on the pins in the fixture, if you have a voltmeter check for voltage across the pins of the fixture once you've cleaned things up. If you get 12V or so then a new bulb should work. If not, then you're likely looking for a broken wire. Try looking in the anchor locker for where the wires are likely routed.. Are these pulpit mounted or in-hull? Either way start tracing wires looking for a break or a lousy connection.
My first bet will be corrosion on the fitting.
Good luck!
chef2sail likes this.
Faster is offline
post #3 of 11 Old 12-08-2012 Thread Starter
halsask
There is some corrosion around the bulb end sockets, I tried to clean it as best I could but did not have a proper tool. Next week when I go to the boat I will take a volt meter and something to clean the end sockets. I sure hope I don't have to start tracing the wires. There must be a junction box or a wire split close by where the wiring splits to port and starboard. Thanks
halsask is offline
post #4 of 11 Old 12-08-2012
chef2sail's Avatar
Does your wire come up through the tubing on the bow like mine does. Sometimes they get corroded and cut at the entrance to the tubing. I would chack the points that faster mentioned first. OE on C&C will eventually allow water and corrosion into the light fixtures. I replaced by port and starboard with a single aquasignal on the bow.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #5 of 11 Old 12-09-2012
Brewgyver's Avatar
This may be a bit obvious, but if you don't have a meter with you, open the working port side light and use the known good bulb to test the starboard.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #6 of 11 Old 12-09-2012
Dirt Free
boatpoker's Avatar
Since International Colregs have for years required sidelights to be above the gunnel and your original lights do not meet current standards for brightness.... it may be a good time to consider new fixtures.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #7 of 11 Old 12-09-2012
I highly suspect this problem is at the fixture. Either the bulb contact inside, which you need to clean up with a file or sandpaper, or at the wire connections behind it. You may have a buried cut wire, but I doubt it, if the other side is coming on. Do they both operate off the same incoming power line?
Jeanneau 54DS
Minnewaska is offline
post #8 of 11 Old 12-09-2012 Thread Starter
halsask
Boatpoker - My running lights are above the gunwale on the bow pulpit so they may have been changed from their original position.
I have exchanged the bulbs in the port and starboard fixtures so the bulbs are good. I hope that it is just corrosion in the bulb holder which I will clean up on my next visit to the boat.
Thanks for all the help. . Hal
halsask is offline
post #9 of 11 Old 12-09-2012
chucklesR's Avatar
As to wiring diagrams - no such thing for 99.9999999 percent of the boats out there. You might find a page or two with esoteric lines and squiggles but there is nothing that says "remove the xxx cover and find the green wire".
Those you make yourself by digging and picking and taking pictures.
For older boats (pre ABYC standards) it'll most likely be white, red, black or what ever was cheapest at the supplier that month, and vary boat to boat.
If it is not the fixture, then it's the wire. More often that not the best way to fix that is to run a new one. Along the way you will find the old one.
chucklesR is offline
post #10 of 11 Old 12-16-2012
asdf38's Avatar
If you end up doing any signifcant work here strongly consider popping in some new LED lights. They'll consume 1/10th the power and never burn out again. I just installed these when my starboard light failed.
Sea-Dog LED Port & Starboard Navigation Light Pair
They actually look better than that picture which has been photoshopped to show the red and green. On the actual light the color comes from the LED and the glass (actually plastic) is clear.
asdf38 is offline
Running light configuration stiffwind Gear & Maintenance 35 04-09-2011 12:10 AM
steaming light, running light, wiring yzlian Pacific Seacraft 4 03-24-2011 09:44 AM
running light switch kgs113 Electrical Systems 1 06-06-2009 07:33 AM
Deck and running light windmutt Jeanneau 1 12-31-2008 12:27 AM
old pearson running light dlathrop52 Gear & Maintenance 1 07-08-2007 10:30 PM
