Promariner 2500 or Xantrex Freedom 2000? - Page 2 - SailNet Community
 1Likes
post #11 of 13 Old 01-19-2013
mitiempo's Avatar
Re: Promariner 2500 or Xantrex Freedom 2000?
There are inverters that have full AC transfer capability without a built in charger. This is one of many examples.
http://www.xantrex.com/power-product.../overview.aspx
Any stand alone charger will be controlled by the appropriate breaker on the AC panel.
chef2sail likes this.
Brian
mitiempo is offline
post #12 of 13 Old 01-19-2013
mitiempo's Avatar
There are inverters that have full AC transfer capability without a built in charger. Xantrex Pro series inverters (1000 and 1800 watts) have both built in transfer switching and remote panels. There are others as well.
Brian
mitiempo is offline
post #13 of 13 Old 01-21-2013
redline's Avatar
I have a Freedom 2500 inverter/charger, so far works fine, but thought I'd mention this approach:
A sistership bought off charter service in St. Maartin has separate charger and inverter, with the charger being 120/240VAC autoswitching, and the inverter straight DC-to-120VAC. The interesting part is that his cabin electrical is connected *only* to the inverter, so his "shore power" is AC-DC-AC at all times, even when plugged into 120V.
He's on a mooring and AFAIK seldom uses AC in these parts, but I kind of like the "go anywhere" appoach to running shipboard appliances without regard to what flavour of AC the marina provides.
And yes, if *either* the charger or inverter fail, he no longer has AC aboard. But still...
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
Xantrex Freedom HF 1800 Help Please svzephyr44 General Discussion (sailing related) 3 10-21-2012 11:37 PM
Xantrex sucks - What replaces an Xantrex Echo-Charger? jarcher Gear & Maintenance 20 07-24-2012 10:03 PM
Xantrex/Heart Freedom 25 -- How to connect Water Heater Bene505 Electrical Systems 64 10-25-2010 12:19 PM
xantrex freedom marine 1500 inverter/charger issues ncstatesailor Gear & Maintenance 1 04-09-2010 07:57 PM
I need a Xantrex Freedom remote panel, Link or Standard, Used or ugly OK TommyboySD Gear & Maintenance 0 04-22-2009 07:33 PM
