Battery Charger AC Wiring Question - SailNet Community
 3Likes
post #1 of 11 Old 01-26-2013 Thread Starter
Irwin 25
andrewalexander's Avatar
I am installing a new battery charger (Guest Intelligent Charger) on the boat (Irwin 25). The new charger has an AC Plug and the instructions recommend plugging into an AC receptacle protected by a GFCI breaker. Is there any good reason or regulation, ABYC or other rules that would preclude me from removing the AC plug from the charger and terminating those wires directly to a dedicated breaker in my AC distribution panel. The bulkhead where I am locating the new charger does not have a whole lot of room and I can save wiring real estate if I do not install an outlet. The run from the new charger to the AC distribution panel is no more than 2. Thanks in advance for any responses.
Andrew
andrewalexander is offline
post #2 of 11 Old 01-26-2013
marcusc130's Avatar
That will definitely void the warranty. You could make an extension with a female plug end that would connect to the breaker panel.
marcusc130 is offline
post #3 of 11 Old 01-26-2013
chucklesR's Avatar
Re: Battery Charger AC Wiring Question
Find the real estate and wire a GFCI outlet.
# 1 cause of boat fires is owner wiring not being up to standards.
chef2sail and Minnewaska like this.
chucklesR is offline
post #4 of 11 Old 01-27-2013
Rules and regulations? No, feel free to hack away. Although if your boat is insured and your hack results in a fire, they may walk away from you because the job is not "up to code".
Look, your charger is saying it is UNSAFE unless it is plugged into a GFI protected source. A GFI is basically a $10 device. If your life is worth ten bucks, go find one and install one. The correct way to do that is to install it as close as possible to the AC inlet on your boat (if you have shore power connection). If you've got no shore power, wire one up at your breaker panel. Whether you buy a GFI-protected outlet, or a short power cord with a GFI in it, or a "box" with a GFI...it is cheap protection.
On moving the generator output from the genset to the breaker panel? I can't see the point in hardwiring it unless, really, spending ten bucks is such anathema to you. Leave the genset alone, leave the warranty alone, leave the genset able to be used off the boat if you had to. Like marc said, buy a two-dollar male plug, wire it up to your AC breaker panel as the *sole* input, and plug it into the genset. You've got more options that way and you've only spent two bucks to do it.
In which case the GFI will have to be in the AC panel, and your charger will have to be plugged into that as well?
hellosailor is offline
post #5 of 11 Old 01-27-2013 Thread Starter
Irwin 25
Marcus/Chuckles....thanks for the suggestions!
Hellosailor...unless someone can reference a code....I am hacking away thank you very much
Andrew
post #6 of 11 Old 01-27-2013
Andrew, the ABYC code calls for a GFI within ten feet of the shore power connection. But as I said--there's no code that binds YOU as a recreational boat owner. ABYC binds builders. Now, if your insurance policy has any language about how modifications have to be made, it might reference ABYC or other codes. And since the charger says it should be plugged into a GFI protected source, again, if you don't do that you are violating the manufacturer's installation instructions, so you are placing yourself at risk. From your insurer, or from a general negligence suit if someone else gets zapped by it.
Tossing the safety warnings and "best practice" recommendations in order to save ten bucks? Feeedom of choice. Having been shocked by 120VAC, I'd spend the ten bucks or do without AC onboard. I don't care about "code" per se but I've learned it often reflects a lot of experience with accident and safety issues.
Wait till you come to grounding your AC equipment, and the questions of what to do with neutral versus ground.
post #7 of 11 Old 01-28-2013
Wish I never found SN!
SimonV's Avatar
I cut the plug and wired direct to the circuit breaker, make sure you have a GFI at the first point of boat AC.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #8 of 11 Old 01-28-2013
Do you know why the manufacturer recommends plugging directly into a GFCI receptacle?
The last boat fire I know of here in RI was about three months ago. Word is, it was caused by faulty electrical work, as most boat fires are (55%). The fire took out the three boats around it as well.
Jeanneau 54DS
Minnewaska is offline
post #9 of 11 Old 01-28-2013
Dirt Free
boatpoker's Avatar
Food for thought ....
Some Irwin 25's were made with Atomic 4 gasoline engines. The battery charger you reference does not appear to be "ignition protected".
If your boat has a gas inboard you cannot install a non-ignition protected battery charger or an AC outlet in The same compartment as the engine or gas tank.
mitiempo likes this.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #10 of 11 Old 01-29-2013
The GFI is to protect you! Install it and make sure you also ground the charger case. I find more chargers not case grounded during surveys. The issue is if the charger shorts in the case and is not grouinded you will get zapped. Remember not to install the charger over the batterries as this will destroy the charger with fumes.
R.Jones is offline
Tags
battery charger wiring
Question about my onboard battery charger? Perithead Electrical Systems 5 04-06-2011 12:17 PM
Wiring question - Echo Charger and Batt Monitor jarcher Gear & Maintenance 22 07-29-2010 01:35 PM
question about Iota battery charger jhaley66 Electrical Systems 7 05-08-2009 06:33 PM
Battery Charger Wiring ? sharedwatch Gear & Maintenance 1 04-09-2009 07:26 PM
Another battery charger question Omatako Gear & Maintenance 1 09-13-2007 03:23 AM
