Old 02-05-2013
robbym48 is on a distinguished road
Fuse panel
Hi,first time poster,new boater! Lots to learn. Accidently shorted one of the fuses on my seachoice rocker switch panel. Remedied situation,push in fuse will not reset. Am I doing something wrong IYO? Do I need a replacement fuse? Thanks for suggestions.
  #2
Old 02-06-2013
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Re: Fuse panel
Is this a fuse or a breaker that tripped?
Bristol 27
Cirque
  #3
Old 02-06-2013
MarkSF is on a distinguished road
Re: Fuse panel
A picture speaks a thousand words. What device is this fuse/breaker protecting?
Bristol 31.1
  #4
Old 02-06-2013
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
Re: Fuse panel
Seachoice was the classic brand name for a 6-switch FUSE panel, square red fuse covers and rocker switches next to each one.
Fuses don't reset, you go out and buy replacements when they blow. Breakers can be reset.
If you have a fuse panel, you aren't pushing anything to reset them, you're just turning the switches on and off, or poking at the fuse covers. On the Seachoice, the fuse holders are opened by pressing in a little tab on the side and letting them pop out. Don't lose the spring that pops them out.
  #5
Old 02-07-2013
redline is on a distinguished road
Re: Fuse panel
Sounds like the fuse/switch panel I had a couple of boats ago. You had to insert a thin tool like a small screwdriver or paperclip into one edge of the square fuseholders to release the fuse cap.
With time what also happened was that on some of the fuseholder caps the plastic arm that sat in the release hole (was supposed) to hold the cap in would gradually bend and no longer keep the fuse tight enough to make good contact. One solution was to find another panel and cannibalize the caps. Better solution was to replace the entire panel with something of better quality.
Norman
s/y "Redline"
1998 Jeanneau SO45.2
  #6
Old 02-07-2013
Re: Fuse panel
Actually I've got a donor panel (4 good fuse holders, two failed) plus a whole new panel, new-in-box, and I'd sell & ship them both cheap if anyone wants to go that route.
You may post attachments
You may edit your posts
Fuse size for fuse panel? SanDiegoChip Electrical Systems 34 10-31-2010 12:22 AM
fuse/switch panel size ozzie1too Electrical Systems 2 06-07-2010 08:56 PM
Remove fuse from older panel? jaschrumpf Electrical Systems 13 02-24-2010 10:14 AM
Electrical Fuse panel perlasowner SailNet FAQ's 2 01-24-2010 12:53 AM
how big should the fuse be ? Roberthussey Electrical Systems 5 04-09-2009 04:01 PM
SEO by vBSEO 3.6.1
