Are portable generators safe? - Page 4 - SailNet Community
 1Likes
post #31 of 37 Old 02-11-2013
chucklesR's Avatar
Re: Are portable generators safe?
Yeah Doug, that's a tad out of the range of a portable generator
I don't have a daily draw on my Irwin yet (too new to me). On my Gemini we managed to just barely fall short with a single 80w and 210ah of AGM's, making 35-40 and using 45-50 a day.
My goal was three days of hang time, then motoring out of the anchorage, into the next caught me up to 100%. It worked.
chucklesR is offline
post #32 of 37 Old 02-11-2013
Captain S/V Triumph
DougSabbag's Avatar
Well, on that boat, I also had a 2000 watt Honda. Which was good to charge the Perkins engine battery if all else failed.
We also had a high output alternator - 165 amps, (I think), besides the regular 90 amp engine battery alternator.
But, until I added the second battery bank, (I raised the floor of the crews quarters cabin ) we were dying in the 3rd day.
After that second bank, we were never running low.... well, when we were, I just switched the banks!
I loved that!
DougSabbag is offline
post #33 of 37 Old 02-11-2013
chucklesR's Avatar
I'd suggest you seriously study up on the chart MS posted and consider it while you are building out your next boat.
I hear ya on the simultaneous charge and drain, but the P effect is real.
The Honda on the Irwin is for running the cruisair, topping off the windlass battery (normally echo charged), emergency charging and (like I said) anything over 1kw that I need to run short term.
I suspect most cruisers are in the same range I'm in, 500-800ah on a single bank, maybe with a starter and windlass battery separate.
I can see a watermaker in my future, but it will be a 8 amp 6 gallon a hour type - and I'll run it at the top of the day when I have 'excess' power to bleed from my solar.
post #34 of 37 Old 02-11-2013
Maine Sail's Avatar
Originally Posted by DougSabbag View Post
We had, (and have again), a fully electric boat.
B&G auto helm (used 12 amps whenever she flexed her muscle)
FrigoBoat refrig
FrigoBoat freezer
Marine Labs Water Maker (SERIOUS POWER DRAINER)
Splendide Washer / dryer powered through a 5000 watt inverter
Numerous pumps
Hot water tank
computers
(2) 18,000 BTU A/C systems
radar
lights
(2) TVs
etc.....
Doug,
You are a prime candidate for LiFePO4 batteries.. Head over to Cambridge and investigate Genasun...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #35 of 37 Old 02-12-2013 Thread Starter
The Blue Sky MPPT website says that you need a minimum of 3.5 amps of panel output per 100 AH of battery capacity to avoid sulfation. The Noco Genius Chargers minimum output for recharging a 100 ah battery is essentially the same. So it seems to be a reasonable number. Given that then you can easily figure out what size battery bank your panels can support. More output would shorten your charging time but at least you have a floor on panel size re your battery bank size. Thanks. Steve S.
sstuller is offline
post #36 of 37 Old 02-12-2013
Omatako's Avatar
FrigoBoat refrig
FrigoBoat freezer
Numerous pumps
Hot water tank
computers
radar
lights
(2) TVs
etc.....
Geez I thought I had the comforts of home aboard - by this standard my boat is bordering on primitive. Although I also have fridge, freezer, watermaker, and all the other fundamentals on the boat but I get away with 6 T105's in the main bank and just one start battery with a separate windlass battery. My daily consumption living on the hook is about 220Ah per 24 hours
I charge with 280w of solar array, a small windgen and a 180A big frame alt and the standard 90A alt on the donk.
But 2400Ah capacity? Wow. I'd have to lift my waterline.
Surely the new boat (if I understand correctly you're busy kitting out a new boat?) will have more electrically efficient gear on board. Watermakers and autopilots of today use just a fraction of the gear described above.
Arthur C. Clarke
Omatako is offline
post #37 of 37 Old 02-17-2013 Thread Starter
An interesting article about gen sets and AGM's can be found on the Electric Boats site in Yahoo Groups (message #23054) where the owner of a Hylas 44 went with the genset - AGM combination. I gave the message number because the link may not work on Sailnet but it works on Electric Boats. Thanks. Steve S.
http://www.c-e-marineamericas.com/re...%20to%20Elect\
ric%20Propulsion.pdf
sstuller is offline
Portable micro electric generators sailaway21 Gear & Maintenance 24 07-30-2012 12:11 PM
Small portable gas generators docrn Gear & Maintenance 55 08-06-2009 09:26 PM
Portable Generators EpicAdventure Cruising & Liveaboard Forum 35 04-28-2009 08:40 PM
Generators wannasail Gear & Maintenance 7 11-17-2002 04:17 AM
Portable Generators -- Hazardous? EscapeArtist Gear & Maintenance 0 07-23-2001 07:37 AM
