where is the temperature sender unit on my BETA?! - SailNet Community
 1Likes
  • 1 Post By chucklesR
post #1 of 7 Old 02-23-2013 Thread Starter
Dufour 27 Newb
Hi All, I seem to be on a roll with all sorts of problems but on the plus side is helping me get to know the engine intimately! So normally when I insert the key into the ignition and do 1 turn, the three warning lights on the control panel (ie. Battery, Oil Pressure, Temperature) would come on together with the buzzer and once the engine starts they all go off after a few seconds! However today the temperature warning did not light up in the first instance and remained off.
I checked the obvious ie the light bulb and the connection on the panel and they are in order. As a next step I would like to check the continuity from the sender unit but was not able to find it? I could not work backwards from the control panel either! Any ideas where it is located on a beta marine 20? Is the fact that it is not lighting a sign that the wire is shorting to earth? Also next I read that I should try and swap the positives of another warning light that is functioning help!
thanks.
jaybeegee is offline
post #2 of 7 Old 02-23-2013
T37Chef's Avatar
you might try the beta forum or contact Stanley at beta USA
Shawn
T37Chef is offline
post #3 of 7 Old 02-24-2013 Thread Starter
Dufour 27 Newb
Re: where is the temperature sender unit on my BETA?!
thanks for that - I didnt know that there are any beta fora - do you have a link?
post #4 of 7 Old 02-25-2013 Thread Starter
Dufour 27 Newb
Update: Here is a photo of what I thought was the oil sensor or is this the temperature sending unit?!
post #5 of 7 Old 02-25-2013
chucklesR's Avatar
You need one of these http://www.betamarine.co.uk/literatu...C-SOM-1011.pdf
Look at the first picture. The heat exchanger is upper right - that wire going into the round piece on the front is the temp sender. It's two spade connectors.
Check page 37 of the pdf in the link for color of the wires and which goes where.
jaybeegee likes this.
chucklesR is offline
post #6 of 7 Old 02-25-2013 Thread Starter
Dufour 27 Newb
thanks for that! The "first" picture was rather intuitive - I have this manual and never saw that wire although my engine is a slightly different layout but I am hopeful that the location of the two spade connectors will be around there. thanks again - will check later in the week and report back!
post #7 of 7 Old 02-25-2013
T37Chef's Avatar
Beta Marine Engines
beta forum fyi
Shawn
T37Chef is offline
Tags
beta , temperature sender unit
Oil pressure sender Hudsonian General Discussion (sailing related) 1 12-15-2010 01:11 PM
Add fuel sender Mystiko Diesel 2 12-06-2009 11:56 PM
Gauge or heat sender unit? scurvy Gear & Maintenance 6 10-05-2007 10:07 PM
mast head sender mike dryver Gear & Maintenance 0 05-14-2006 06:37 PM
First Challenge and Success-- Temp Sender Jim H Atomic 4 0 04-10-2006 09:04 PM
