Charging time and charger output - Page 2 - SailNet Community
 4Likes
post #11 of 15 Old 03-03-2013
outbound's Avatar
Re: Charging time and charger output
so basically fast charging is like the de sulfatization setting on some smart chargers? How about rate of discharge? Does running high load devices separately or together matter? In past always tried to avoid running them together if possible. Is that wrong?
s/v Hippocampus
Outbound 46
outbound is offline
post #12 of 15 Old 03-03-2013
Maine Sail's Avatar
Originally Posted by btrayfors View Post
Good question.
I don't have any objectively verifiable evidence, but from "feeling" and from comments made by battery manufacturers who have collaborated in some of my research I believe there is reason to believe that charging the batteries as fast as they will accept current is good for them.
This may or may not be due to internal bubbling which could help avoid stratification of the electrolyte and, possibly, speed up the process of dislodging loose PbSO4 deposits on the plates.
Maybe MaineSail has a view on this.
Bill
I think having both types of charges available is often best. This can be especially true with thick plate deep cycle batteries where high charge current tends to build surface charges that don't penetrate the plates as effectively as a slow charge will.
The fast charge will "shake" things loose, limit stratification and with good voltage can help to minimize sulfation.
On the other side a good slow charge of a thick plate deep cycle battery is perhaps the best way to get it chuck full and push the charge deep into the plates. Mixing things like wind & solar with high amp charge sources can be a productive way to handle batteries..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 15 Old 03-03-2013
outbound's Avatar
thanks to both you gentle men. you two know what you know.lets just hope I know what I don't know.
s/v Hippocampus
Outbound 46
outbound is offline
post #14 of 15 Old 03-03-2013
Maine Sail's Avatar
It really depends on what batteries you have. Thick plate deep cycle batteries don't tend to deal as well with high loads as other types but this is more of a voltage drop issue to the equipment than overly detrimental to the batteries. Any load above your banks Ah capacity corrected Peukert will result in less Ah than the bank is rated for but a good battery monitor will keep track of this.
______
post #15 of 15 Old 03-07-2013
norahs arc's Avatar
You have received some excellent advice from the members here. There is one thing I will mention. Check with the battery manufacturer for charge rates and times. They should be able to supply information such as max voltage and max amps and times. They will also specify an equalization schedual with voltage and amp rates. (Equalization requirements vary between battery types and sizes.)
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
Battery Bank Combining for Charging –Sterling B2B Charger or Blue Sea ACR? djwindrifter Electrical Systems 7 11-08-2012 07:08 PM
Charging two batteries on one charger Barquito Electrical Systems 17 12-25-2011 12:56 PM
Weird Charging Problem with Xantrex Charger Sailor-man Electrical Systems 6 06-20-2011 09:57 PM
Replacing Trickle Charger with 3 stage charger jasoncandace Gear & Maintenance 6 10-17-2010 07:27 PM
Engine will not crank and required charging time ekenna Electrical Systems 12 05-14-2010 07:50 PM
