cranking battery - SailNet Community
post #1 of 20 Old 03-13-2013 Thread Starter
cranking battery
The cranking battery on my 35`saga died over the winter, I replaced it and the new one died as well. The boat is on shore power. I can't think of anything that is drawing on this battery? Any ideas would be appreciated. Thanks
beefvet is offline
post #2 of 20 Old 03-13-2013
Re: cranking battery
What type of battery is it?
The simple answer could be that batteries do not have infinite lives and she's done.
Disconnected batteries all have self discharge rates, with flooded cell being the highest. They must be routinely charged over the winter. Gels and AGMs have slow discharge rates and, while still a good idea to keep topped up, are much easier to do so.
If you are saying that you left it plugged into shore power all winter, again, it just may be too old. If fairly new, I would begin to ask the compatibility of your charging system and battery type. Some mistakenly replace their battery without regard to the previous type and their chargers ruin the new batt.
Welcome to SN.
Jeanneau 54DS
Minnewaska is offline
post #3 of 20 Old 03-13-2013
chucklesR's Avatar
If it's plugged in and on the charger you'll need to look to the charger, and pry open the caps and see if the electrolyte has boiled off.
Otherwise, you'll have to define 'died' so the experts can help.
chucklesR is offline
post #4 of 20 Old 03-13-2013 Thread Starter
Thanks, the cranking battery is new. The boat is on shore power which keeps the house batteries charged. Is it normal for the cranking battery to also be charged in this way? I think the cranking battery is only used for starting the engine? There should be no drain on it when the boat is not used?
beefvet is offline
post #5 of 20 Old 03-13-2013
chucklesR's Avatar
Batteries self discharge 2% or so a month.
Still, it depends on how your charger 'charging the house bank' is set up - what keeps the charger from also charging your start battery (switch, no connection etc..).
If it truly is separate you need to look for a ground in your start circuit. Start with the mark 1 eyeball looking for bare wires, and progress through any and everything on the boat (bilge pumps are a prime source).
post #6 of 20 Old 03-13-2013
Stu Jackson's Avatar
You need to explain how it is wired. And how the start battery is charged.
Try these:
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: Basic Battery Wiring Diagrams
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
1/BOTH/2/OFF Switches Thoughts & Musings - SailboatOwners.com
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #7 of 20 Old 03-13-2013
chef2sail's Avatar
Also what tyoe of batteries? Are they matched? All wet cells, AGMs or Gells? All deep cycle?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #8 of 20 Old 03-13-2013 Thread Starter
Sorry, the boat is a 1000 miles away, and kinda new to us. The batteries are all wet cell. 1 SB 12v , 4 HB 6v. They are charged through the in house inverter. I know the HB are being charged but I guess the SB is not. I will be at he boat in a couple of days to try and sort it out. Thanks for your help.
beefvet is offline
post #9 of 20 Old 03-13-2013
mitiempo's Avatar
The inverter /charger, at least any I have seen or installed, has a single DC output which is also its DC input. For it to also charge the start battery you would need to have a device like an Echo Charge, Balmar DuoCharge, or an ACR or other type of combiner. If you do not have one of these devices you would have to leave the main battery switch in both for the start battery to receive a charge.
Could this be the issue?
Brian
mitiempo is offline
post #10 of 20 Old 03-13-2013
Señor Member
PorFin's Avatar
I'm dubious. An inverter takes 12v DC from the batteries and converts it to 110v AC. If your battery charger is being run off of the inverter, you have a real problem.
As others have said, I think you should map out your charging circuit. I'm guessing that you have a battery charger in there somewhere, and what kind it is and how it is set up will make a difference.
More sleuthing is in order...
________
'85 BYB Vagabond 39
PorFin is offline
CCA - Cold Cranking Amps question The Sailing Podcast Diesel 13 09-23-2012 10:41 PM
Why have a cranking battery? MaviAtta Electrical Systems 3 03-15-2011 08:07 PM
New Battery charger (unplugged) causes spark on battery post!! Northeaster Gear & Maintenance 15 11-17-2008 08:30 PM
hand cranking wumhenry Gear & Maintenance 15 12-02-2007 05:01 PM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 12:43 AM
