one of 4 batteries have excessive buildup on the positive post. - SailNet Community
 1Likes
  • 1 Post By norahs arc
post #1 of 6 Old 03-25-2013 Thread Starter
bristol299bob's Avatar
I checked the batteries this weekend for the first time since fall (4-5 months) and was surprised to find a large amount of buildup on the positive post of one (of 4) house batteries.
I dont have a battery monitor but I do have volt and amp meters wired in the panel so i keep a casual eye on the batteries. I check voltage and amperage upon arrival at the boat. I'm not fanatical about physically checking the batteries, I generally check water level 2 or 3 times a year.
The buildup has the consistency of a snow cone (granular and damp). Greenish in color. It was not a dry powder as you might find on a car battery.
Pics below.
What is this stuff? Is this a sign that something is wrong (either my maintenance or wiring)?
every other battery post and clamp were literally clean as a whistle.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
post #2 of 6 Old 03-26-2013
Have a go and DIY .....
Re: one of 4 batteries have excessive buildup on the positive post.
Any signs of acid corrosion on batteries are signals that the battery is damaged and may need to be replaced soon.
Or do an internet search with the problem.
macwester26 is offline
post #3 of 6 Old 03-26-2013
my opinion is that the post is not sealed within the top case of the battery and gasses are venting out.
bandaidmd is offline
post #4 of 6 Old 03-26-2013
Tartan 27' owner
CalebD's Avatar
I had this happening on my car battery on both (+/-) posts not long ago.
I had to replace the cable connectors as the originals were bent out of shape and not making a good connection with the post.
Not long after the new connectors were put on I had to replace the battery.
Everybody has one:
CalebD is offline
post #5 of 6 Old 03-27-2013
norahs arc's Avatar
A solution of soda and water will clean it up. After cleaning remove and replace the battery. Check the battery cable connectors as the build up may have damaged them.
(This build up is a sign that the battery is leaking.)
bristol299bob likes this.
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
post #6 of 6 Old 03-27-2013 Thread Starter
thanks all.
So, any caveat in replacing one of 4 batteries? They are all over 5 yrs old, still seemingly all performing well.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
Fiberglass buildup around rudder stuffing box sailorgirl31 Gear & Maintenance 13 03-23-2013 07:14 PM
Sailor's secret Olympic buildup NewsReader News Feeds 0 10-18-2011 01:30 AM
buildup in poo hose HoffaLives Gear & Maintenance 16 12-19-2007 07:22 PM
water tank buildup smaconf@msn.com Hunter 2 11-30-2007 08:51 AM
