New alternator and DS issue - SailNet Community
 1Likes
  • 1 Post By Maine Sail
post #1 of 5 Old 04-17-2013 Thread Starter
Here's an odd one for you gurus..
We recently upgraded to a high output alternator, smart reg and ACR. Very happy with it all overall....
But our venerable old Signet LCD depth sounder is acting up. Our previous max voltage due to the old diode isolator was maybe 13.2V.. Now we're up to 14V and if the engine's running the DS reads overrange regardless of depth. Shut down and as soon as the system voltage drops to resting it works fine.
Any ideas?. Thanks.
Faster is offline
post #2 of 5 Old 04-17-2013
chucklesR's Avatar
Re: New alternator and DS issue
What comes around goes around.
Looks like your old depth sounder is voltage oriented and you'll need to adjust it to a known depth. Should be a pot on it.
Or the alt needs to be adjusted down in output voltage. I'm not a expert but I thought alts were set to either 14.1 or 14.3 depending on battery type - for those you can adjust anyway.
chucklesR is offline
post #3 of 5 Old 06-07-2013 Thread Starter
Just to wrap up this issue...
We tried ferrites, IC voltage regulation, mechanical shielding to no avail so...
We bought a new but discontinued Raymarine ST40 depth meter and connected it to the original Signet transducer. It works great, none of the alternator interference that was plaguing the Signet, and on top of that, where the Signet used to top out at around 120 feet, we now read down to 275 so we've gained there too.
Pleasant surprise, avoided changing transducers, and got it at a discount as well... good news all around!
Faster is offline
post #4 of 5 Old 06-07-2013
Maine Sail's Avatar
Any ideas?. Thanks.
If you suspect it is over voltage related throw a diode in the + feed to the sounder. This will drop the voltage about .6V. If that does not do it throw two in series...
Faster likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 5 Old 06-07-2013 Thread Starter
We tried that too... ultimately I was concerned about too LOW voltage when not charging.. in any event it didn't help. I then used a 3pin IC LM7812 12V regulator, same result.
I'm happy with the situation now..(see post #3 above) better display, better range, didn't have to change transducers.. glad to have 'depth' back when powering! AND efficient charging!!
Faster is offline
Alternator wiring issue... Faster Electrical Systems 23 04-10-2013 09:30 PM
A4 alternator? seaspot Atomic 4 31 04-01-2013 04:27 PM
Inverter issue (maybe alternator based) contagous Gear & Maintenance 17 08-04-2010 07:03 PM
Anyone know anything about alternator? preservedkillick Gear & Maintenance 14 10-26-2008 09:44 PM
alternator help. hwkmoon Gear & Maintenance 1 12-26-2000 04:12 AM
