Connection strap from meter shunt to negative bus - SailNet Community
post #1 of 1 Old 04-19-2013 Thread Starter
Somewhere on the web, I saw a photo of an install (probably by Maine Sail) in which the volt/amp meter shunt was installed an inch or so away from the ground bus, and the two were connected a short, rigid jumper of some sort.
I'm reconfiguring my distribution in a similar fashion, and I'm thinking that a strap like this would work much better than a 1 inch battery cable. Could I flatten out a copper water pipe section and drill for the studs? I could use a plumbing torch to tin it with solder if that made a difference.
Rusty123 is online now
Help with DC negative question josrulz Electrical Systems 11 03-27-2012 12:34 PM
Red Rubber Preventer Strap with Bronze Rings in Ends yawlboy Gear & Maintenance 1 01-06-2012 02:36 PM
Boom strap for loose foot mainsail? PalmettoSailor Gear & Maintenance 6 11-28-2011 02:58 PM
Negative Reputation? arf145 Announcements and Suggestions Box 22 04-07-2011 09:29 AM
Galley strap MarkMiner Gear & Maintenance 3 01-09-2007 03:33 PM
