Alternating confusion... - SailNet Community
post #1 of 1 Old 04-19-2013 Thread Starter
Canuck Sailor
Send a message via Skype™ to canucksailorguy
I'm trying to figure out how to properly install the new alternator I purchased. It's a Hitachi with internal regulator. I know that one terminal goes to the momentary contact on the key switch to 'excite' the alternator, and the other goes to the warning lamp. Problem is, the boat once had an external regulator and I can't figure out how to rewire the setup to work properly.
The wiring diagrams I've looked up online don't seem to show which contact on the key switch to connect to - they just show the wires going to the key switch.
Do I run the lamp wire to a bulb (warning lamp), and then to the key - but do I run this wire to the 'on' contact for constant power? I can't see it going to the momentary switch, that doesn't make sense.
All help graciously accepted and please - TYPE SLOWLY! I'm not real good at this stuff!
Thanks...
Cuba - Forbidden Paradise
canucksailorguy is offline
Lowrance AIS Confusion.... GrahamO Electronics 6 12-14-2012 08:53 AM
Confusion: spinnaker, gennaker? boz86 Learning to Sail 11 07-05-2012 10:27 AM
Fiberglass Confusion SailingAlien Gear & Maintenance 4 05-29-2009 12:36 PM
Link 20 confusion. chris_gee Gear & Maintenance 3 01-28-2009 01:57 AM
Bulkhead Confusion RichP Sailboat Design and Construction 10 11-08-2008 03:49 PM
