Blue Sea Battery meter with two banks - SailNet Community
post #1 of 3 Old 04-20-2013 Thread Starter
I'm replacing the high current wiring on my boat -- two banks, primary and reserve. The boat already has a voltage/amp meter (Blue Sea 8248).
There is a good thread about installation of a shunt with two banks at this thread, but that's for a Victron meter, which is designed with two voltage inputs.
The Blue Sea meter only has one voltage input, so measuring voltage on two banks requires the installation of a switch on the voltage sensing lead. Blue Sea has a nice tutorial here.
But here's the rub: Blue Sea says that to measure voltage on two banks, the banks must share a common ground (that is, both connected to same side of shunt). But as described in the Victron thread, connecting both banks to the same side of the shunt will prevent monitoring of bank-to-bank current (although this would seem to complicate consumption calculations).
Since the voltage drop across the shunt is so small, I'm inclined to ignore the Blue Sea direction, and connect the bank negatives the way Victron describes.
Does anyone see any "gotcha's" with this plan?
Rusty123 is offline
post #2 of 3 Old 04-20-2013
Maine Sail's Avatar
Re: Blue Sea Battery meter with two banks
None of this really matters with a simple ammeter/voltmeter as it is not counting Ah's or keeping track of Peukert/SOC. They simply show what is happening at a specific point in time (a snap shot) across the shunt..
If you had a true battery monitor then yes the position of the aux battery on the shunt would matter because it is actually doing something other than displaying the "at a glance" current.. With a simple ammeter is is not critical where the AUX batt is wired. Just wire an A/B to see voltage of a second bank..
I still prefer to have an aux battery on the load side of a house bank shunt but in this case it is not "critical"..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 3 Old 04-21-2013 Thread Starter
Thanks, that makes sense. I'll add a real battery monitor to my Christmas wish list!
Rusty123 is offline
Battery banks must be the same or can be different? edwmama Electrical Systems 6 11-16-2010 02:39 AM
Battery Banks islands50 Gear & Maintenance 2 04-19-2010 08:52 AM
Battery Boxes and Banks arf145 Electrical Systems 21 03-12-2010 11:03 AM
Battery Chargers for Multiple Battery Banks btrayfors Electrical Systems 5 11-15-2009 11:57 AM
Battery Banks 1 or 2 SimonV Gear & Maintenance 9 10-25-2007 09:25 PM
