Is the Victron shunt the same size as the Blue Sea shunt? - SailNet Community
post #1 of 1 Old 04-21-2013 Thread Starter
As mentioned in another thread, I'm redoing my high current wiring. Rather than bolting everthing directly to the bulkhead, I'm attaching all the gear (bus bars, ACR, switch, etc.) to a piece of marine plywood (with machine screws and t-nuts), which I'll then attach to the bulkhead.
I've got a Blue Sea multimeter, and have attached the shunt to the plywood. Based on recommendations from that other thread, I envision installing an additional Victron monitor at some point in the future. To make things easier, I'd like to install the t-nuts for the Victron shunt now. Based on photos, the Victron shunt looks identical to my Blue Sea shunt (with the exception of the circuit board). Can anyone verify that they are the same size? (If so, I'll just use the Blue Sea shunt as a pattern to install the t-nuts).
Thanks!
Rusty123 is offline
Connection strap from meter shunt to negative bus Rusty123 Electrical Systems 0 04-18-2013 11:22 PM
Does the Starting battery also need to be wired behind the Victron BMV-602S shunt? CapTim Electrical Systems 12 01-25-2013 05:01 AM
Shunt for panel ammeter? patrickstickler Gear & Maintenance 8 06-09-2011 10:51 AM
Kuldging an Ammeter Shunt? hellosailor Electrical Systems 4 01-22-2011 04:07 PM
Link Battery Monitor Shunt Installation SteveInMD Electronics 0 07-22-2009 02:42 PM
