Balmar 614 vs. ARS-5 Regulator - SailNet Community
 1Likes
  • 1 Post By Maine Sail
post #1 of 7 Old 04-24-2013 Thread Starter
Tartan 37C
T37SOLARE's Avatar
Looks like my old Balmar 512 regulator has bit the dust. I'm seeing anywhere from 15 to 18 VDC when it should be maxed at 14.3-14.4V.
Tech support at Balmar says the internal voltage sensor must be shot and recommended replacing with the ARS-5. Looking at online pricing the difference is only about $20, so why not go for the 614?
Anyone have experience with both?
125 Amp alt
440 AH AGM bank
EchoCharger for the start batt
SOLARE
T-37 #442
T37SOLARE is offline
post #2 of 7 Old 04-24-2013
Re: Balmar 614 vs. ARS-5 Regulator
Virtually identical setup as you... chose the 614. Why not have the extra features/programming for the small cost? Have not used the ARS-5, though, so YMMV
Faster is offline
post #3 of 7 Old 04-24-2013
Maine Sail's Avatar
614 can drive a higher field current and voltage (some alts require this). It has a dedicated "volt sense" wire not a shared power/volt sense. It has more programming options and IMHO is worth the $20.00 if for no other reason than the dedicated voltage sense wire.
fidalgo likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 7 Old 04-24-2013 Thread Starter
Tartan 37C
T37SOLARE's Avatar
Great thanks!
Ordered the 614 will let you know how it goes. Should be a plug & play replacement, in theory that is....
SOLARE
T-37 #442
post #5 of 7 Old 04-29-2013 Thread Starter
Tartan 37C
T37SOLARE's Avatar
Just wanted to update this.
The old 512 was shot and the 614 is great, easy to program and works like a champ. The wiring was not plug and play like the factory said, but no big deal to change.
Thanks for the advice, well worth the extra $$
SOLARE
T-37 #442
post #6 of 7 Old 05-09-2013
Hello T37SOLARE, have you used both 512 and 614. What is the variation between 512 and 614 models, which is better from your point of view?
electronics assembly
jorn85 is offline
post #7 of 7 Old 05-09-2013
Puget Sound Pounder
kellysails's Avatar
I have an ARS 5 supporting a series 95 alt. I was going to get a 614 but the yard says it is not needed, the ARS has a very long sable track record.
kellysails is offline
Balmar regulator advanced programming (long) rbarkas Electrical Systems 11 04-04-2011 09:38 PM
balmar regulator question granche1 Electrical Systems 4 09-29-2010 07:11 PM
Balmar Regulator sailing320 Gear & Maintenance 8 01-14-2010 10:27 PM
Balmar regulator and combiners Edo Kazumichi Gear & Maintenance 1 09-06-2009 03:44 PM
Balmar? scosch Gear & Maintenance 5 03-03-2008 09:45 PM
