Charging: Gel vs AGM - SailNet Community
post #1 of 7 Old 04-29-2013 Thread Starter
I have an old(er) Guest Charge Pro 2606 Gel battery charger. The newer model is the 2606A, the "A" meaning that it has been tested to work with AGM batteries (http://www.amazon.com/Guest-2606A-Portable-Battery-Charger/dp/B000NI38EE).
I have an AGM battery that I would like use as a replacement for my existing Gel battery and I'm trying to figure out if the 2606 charger will work with the AGM battery.
I called Guest and the max voltage of the charger is 14.5 volts, with a float charge at 13.1-13.5 volts Calling the AGM battery manufacturer, the required float charge for my battery is 13.5-13.8 volts. Does anyone have experience intermixing "Gel" chargers with "AGM" batteries? It seems like my charger would work just fine - but I can't seem to find any good advice. Looking at new chargers, no one publishes the voltage specifications. They all just say they can be used with both battery types.
Thanks for any insight.
cas8100 is offline
post #2 of 7 Old 04-29-2013
Re: Charging: Gel vs AGM
All chargers that I've seen that will work with different types, have a manual switch to tell it which it is charging. I do not believe you can use a Gel charging profile to properly charge an AGM, or vice versa.
Regardless of how you charge a battery, it will take a charge and work for a bit. The issue with charging properly is that you maximize its longetivy or don't ruin the battery in the process. For example, you can boil bubbles into Gel electrolyte by overcharging or sulphate an AGM by not fully charging it.
Jeanneau 54DS
Minnewaska is offline
post #3 of 7 Old 04-29-2013 Thread Starter
None of the Guest marine chargers have a switch and they're advertised as general purpose chargers for flooded, gel, and AGM type batteries. The Guest technical support folks are also telling me that their chargers work with both battery types. I'm guessing I'm just looking too deep into this as there is very little information on the internet about matching battery + charger types.
cas8100 is offline
post #4 of 7 Old 04-29-2013
Maine Sail's Avatar
Originally Posted by cas8100 View Post
I have an old(er) Guest Charge Pro 2606 Gel battery charger. The newer model is the 2606A, the "A" meaning that it has been tested to work with AGM batteries (Amazon.com: Guest 2606A Portable Marine Battery Charger (12-Volt, 6-Amps, Single Output): Sports & Outdoors).
Ideally you should not have been charging a GEL battery with that charger. 14.5v is WAY to high for GEL's. 14.1V is where you will get the longest life.. That charger will work with AGM but the float profile is a tad low. Still this charger should not be used as a primary charger for your bank. It is a portable charger not designed nor intended for charging house banks on a regular basis.
If this is going to be on a boat you want an "installed" charger intended for that use. The Promariner Pronautic P or the Sterling ProCharge Ultra are excellent and they make them as small as 10A...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 7 Old 04-29-2013 Thread Starter
MaineSail,
Thanks for the response. I guess that's what I get for listening to the sales guy at the big blue. The boat is moored and I don't have any access to power (don't have solar....yet) so I end up removing the battery after each trip out. The 75 lb battery will be an absolute bear to lug around so it may speed up my investigation (and investment) into solar.
I just didn't want to harm the new AGM battery with my existing charger, which for a short term solution, it doesn't look like it will.
Thanks again.
cas8100 is offline
post #6 of 7 Old 06-08-2015
What concerns me is the warnings on my Road Runner AGM battery; don't under charge or over charge, never use a trickle charger, use only a good fully automatic, adjustable temperature sensing voltage regulated charger that will shut down completely at full charge! Wow! Where can you find/buy such a charger? And, at what price?
I have a Die Hard12/2 Amp Fully Automatic Microprocessor Controlled Model 200.71223, but the manual doesn't mention any of the characteristics indicated by the battery manufacturer. I, also, have a Guest Charge Pro model 2606 that I used with gel batteries.
Any thought on which one to use with AGM?
Smith June 2015
bluebird4 is offline
post #7 of 7 Old 06-08-2015
Maine Sail's Avatar
Smith June 2015
See the post above yours that guidance still stands. BTW Roadrunner AGM's are nothing more than Deka AGM's. Follow Deka charge guidance...
______
Battery charging northbay Gulfstar 7 12-24-2008 09:45 AM
Batteries not charging Crunchtime Gear & Maintenance 5 09-06-2008 03:40 PM
Battery charging Chaunclm Gear & Maintenance 8 08-31-2008 10:04 PM
Charging Issues Sue & Larry Gear and Maintenance Articles 0 08-28-2001 08:00 PM
Charging Batteries navtron Gear & Maintenance 1 01-12-2001 05:57 AM
