Tartan 30 Wire Chase - SailNet Community
post #1 of 3 Old 04-30-2013 Thread Starter
On my Tartan 30 several wires, including those from the engine panel and the 8GA positive wire to the main switch panel, run for an extra 20ft for no reason I can determine.
The wires run aft from the panel (just port of the companionway) down a raceway under the cockpit seat and all the way back to the port lazarette. Once in the lazarette, they make a U-turn and run down another raceway next to the port quarterberth and forward under the port berth, into the head. Once the wires exit this raceway they make another pair of turns under the sink and back into the engine compartment.
As far as I can tell, about 20ft of this could be cut out by just going straight from the main panel over the quarterberth down to the settee and then straight to the engine and battery compartments. This skips the run to the lazarette for all the wires (excluding the stern light pos and the rear bus neg) and through the head (excluding the engine panel wires).
My boat layout matches this diagram on the port side.
(from S&S blog).
Can anyone here either explain why Tartan didn't use the shorter run or why I shouldn't?
I'm going to be replacing quite a bit of wiring and cutting out those 20ft would make me feel a lot better about the 8GA main positive wire and let me avoid snaking wire down these really long raceways.
1975 Tartan 30 Competition Rig
Last edited by eko_eko; 04-30-2013 at 08:45 AM. Reason: Replacing huge image with link
eko_eko is offline
post #2 of 3 Old 04-30-2013
Asleep at the wheel
jimgo's Avatar
Re: Tartan 30 Wire Chase
I wonder if they wired the boat before the deck was put in place.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 3 Old 04-30-2013 Thread Starter
The red line is the existing run. The green line is my proposal.
Click for full size.
eko_eko is offline
Guard: 2 kids rescued after Calif. boat chase - USA TODAY NewsReader News Feeds 0 09-15-2012 07:30 PM
Guard: 2 kids rescued after boat chase off Calif. - The Associated Press NewsReader News Feeds 0 09-08-2012 05:50 AM
Bryan Chong's first hand recount of the Low Speed Chase tragedy NewportNewbie General Discussion (sailing related) 316 08-17-2012 06:19 PM
Dual waterspouts chase sailboat Digiital General Discussion (sailing related) 15 02-28-2008 08:26 PM
Hull YC 2006 Great Chase Race ! NewsReader Mass Bay Sailors 0 08-11-2006 08:15 AM
