Question about six volt GC batteries - SailNet Community
 3Likes
post #1 of 15 Old 05-05-2013 Thread Starter
Does anybody know if there is a six volt GC battery that is available with separate auto post and stud terminals? They are called "marine" terminals. It is much easier to make connections when the post and stud (wing nut) connections are separate. The Trojan T-105 isn't available with this type. Thanks. Steve S.
sstuller is offline
post #2 of 15 Old 05-05-2013
Re: Question about six volt GC batteries
You mean like this ?
Source: Blain's Farm & Fleet Golf Cart Battery
What are you pretending not to know ?
Please support my
wind_magic is offline
post #3 of 15 Old 05-05-2013 Thread Starter
That's what I'm looking for. I'll have to find out if they are available in Florida. Thanks.
sstuller is offline
post #4 of 15 Old 05-05-2013
Here is something similar in Florida.
(I can't fix the link, Sailnet just keeps mangling it no matter what I try, just go to the site and look at the batteries)
Source: O'Reilly Auto Parts
Please support my
Last edited by wind_magic; 05-05-2013 at 07:05 AM. Reason: Sailnet's Link Mangler strikes again
post #5 of 15 Old 05-05-2013
it might be more economical to replace the ends of the cables and go with a cheaper battery
attitudeadjustment is offline
post #6 of 15 Old 05-07-2013
Irrationally Exuberant
Or use something like this to add a stud:
http://www.amazon.com/Battery-Terminal-Connectors-18-Stud/dp/B008QJ55LQ
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #7 of 15 Old 05-08-2013
mitiempo's Avatar
Trojan T-105 batteries are available with 5 different terminal types. I have never had an issue with the standard "wing nut" terminal. Best to keep connections on the battery to a minimum - use separate buses to keep the battery connections to one each for positive and negative, with the possible exception of temp sensors.
And throw the wing nuts away and use conventional nuts with washers. ABYC doesn't allow wing nuts as they can't be torqued down enough without breaking.
The T-105 description below shows the 5 connection options on the right side. The second describes the terminal types.
Brian
mitiempo is offline
post #8 of 15 Old 05-08-2013 Thread Starter
Thanks for the info on the T-105. However it confirms that the T-105 is not available with the #6 connector. The previous post mentions the clamp-on connector with a stud. Unfortunately you lose the use of the post for connections with a clamp-on lead.
Having to add a busbar because you don't have a stud on the battery adds a lot of complication. I love wingnuts on battery terminals in spite of AYBC. They must be a good idea because battery manufacturers don't provide them anymore. Batteries now come with regular nuts which are cheaper. I am sure this is their primary motivation for providing them.
sstuller is offline
post #9 of 15 Old 05-08-2013
mitiempo's Avatar
Adding bus bars does not add to the complication - it keeps the batteries neater and easier to check fluids as well as cleaning of the tops. There is nothing messier than a bank of batteries with wires going every which way from the posts. As far as wingnuts go, they can't be wrench tightened to the proper torque and this can lead to loose connections and the problems that brings. I think many with small outboard boats like the wing nuts but they have no place on a proper marine battery installation.
I recently installed a bank of 8 golf carts and a large inverter on a 48' boat. Positive from one end of the bank and negative from the other end to draw the bank down evenly. The only extra connection was a temp sensor which went to a battery in the middle. The main posts had only one connection each which went to buses. A neat installation that is simple to service and trouble shoot if necessary.
Trojan batteries have studs - and you only need one per battery. The standard stud works very well.
Brian
mitiempo is offline
post #10 of 15 Old 05-08-2013 Thread Starter
One observation about wingnuts. They avoid the safety hazard created by having to use a wrench on battery terminal fittings. Wrenches seem to act as if their job is to make a connection between battery posts. Thanks.
sstuller is offline
Replacing 12 volt batteries with 6 volt justonemoreproject Electrical Systems 11 03-15-2012 10:13 PM
Mixing 6-volt and 12-volt Batteries? captainfrank Gear & Maintenance 3 11-08-2008 12:33 PM
6 volt golf cart batteries hollyp Gear & Maintenance 6 12-02-2007 06:38 PM
6 Volt Question Newport41 Gear & Maintenance 7 03-28-2007 04:16 AM
6 Volt Batteries vs 12 Volt ABullard Gear & Maintenance 10 09-06-2001 06:41 PM
