12V Connectors - Page 2 - SailNet Community
 1Likes
post #11 of 26 Old 05-12-2013
mitiempo's Avatar
Re: 12V Connectors
While you could use spade or bullet connectors but they do corrode and loosen over time. The best solution is probably to add ring terminals with heatshrink on both the feed wires and the wires from the pump and use a terminal strip.
Brian
mitiempo is offline
post #12 of 26 Old 05-12-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: 12V Connectors
I have thought to use the two pin european outlets for 12v. Similar to US two spade, but not interchangable.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #13 of 26 Old 05-12-2013
Re: 12V Connectors
Andersen PowerPoles are great, the only catch being they are a *itch to crimp unless you use the matching Andersen crimping tool. If not, they are hard to assemble and easy to mangle.
A US two-blade AC plug should actually be polarized if it has been made in the last 10? 20? years. They all use one wider blade for the ground side and will not plug in when reversed. That's instead of the 3-pin grounded plugs, which are also polarized so the wide blade fits only in the neutral side.
I'd avoid any type of AC standard connector though, simply because "one of these days" someone might just find a way to plug it into something else that matches. I call that "laying land mines".
hellosailor is offline
post #14 of 26 Old 05-12-2013
asdf38's Avatar
Re: 12V Connectors
Heh, all the various suggestions fully demonstrate the sad state of this question. Again it's sort of a pet peeve of mine because I specify electronics and connectors (though usually PCB connectors) all the time and still don't have a great answer.
Though all the suggestions are good. The Radioshack connector is a standard but not sealed in any way, it can be found with gold contacts. And andersons are a nice simple standard.
However I did just notice that McMaster has a line of waterproof DC connectors. Personally, I would strongly consider these if I were installing connectors.
McMaster-Carr
asdf38 is offline
post #15 of 26 Old 05-12-2013
Re: 12V Connectors
if the weather proof ones that mcMaster sells are anything like the ones in my car, they should do well. Definatly something that would work well on electrical componates that need to occasionally be unplugged for service
Art Haberland
post #16 of 26 Old 05-12-2013
Re: 12V Connectors
How about wiping di-electric grease across the terminal block. Can't figure out how it would ever corrode. A bit messy, however, to R&R.
Jeanneau 54DS
Minnewaska is offline
post #17 of 26 Old 05-12-2013
Re: 12V Connectors
Well, there is a standard. Every gizmo with a wall wart uses one of those damned coaxial power plugs, and there are some specs about which size plug to use with different voltages and wattages. So if you don't mind wiring up the plug and socket and the soldering nuisance...coaxial power plugs, wallwart style. Power on the plug, device on the socket, which is probably going to be reversed from what you'd want on a boat.
The "super" USB3 standard might also work, that's designed for higher voltages and power IIRC. (IF)
post #18 of 26 Old 05-12-2013
MarioG's Avatar
Re: 12V Connectors
I use the Anderson connectors at the boat yard and have yet to see any corrosion develop.
Endeavour E-32 "Samara"
I am the Capt of my ship but sometimes I think I had more fun just being the cabin boy.
MarioG is offline
post #19 of 26 Old 05-12-2013
Maine Sail's Avatar
Re: 12V Connectors
You can always use solar MC-4 connectors as they are IP68 rated and capable of 20A...
Terminating Solar MC-4 Connectors (LINK)
kd3pc likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #20 of 26 Old 05-13-2013
Re: 12V Connectors
If you want duplex and they will usually be connected, the Delphi Weatherproof car connectors appear to be inexpensive, fairly well sealed, and secure.
KarlP is offline
Heat shrink connectors minnow1193 Electrical Systems 16 07-09-2012 11:41 AM
Euro-style connectors LookingForCruiser Gear & Maintenance 2 06-15-2009 08:09 AM
Source for AC wire connectors? floatsome Electrical Systems 6 04-08-2009 06:07 AM
12V electrical connectors 88' PSC34 mondofromredondo Pacific Seacraft 2 11-28-2008 01:00 PM
Thru-deck 12v connectors? Jonathan316 Gear & Maintenance 1 06-11-2004 08:10 AM
