Inverter for hot water tank - Page 2 - SailNet Community
 1Likes
post #11 of 15 Old 05-29-2013
Re: Inverter for hot water tank
Originally Posted by JimsCAL View Post
Unfortunately, this doesn't change the amount of energy that a battery can store and how much water it could heat. Those low wattage elements will only increase (signficantly) the time it takes to make hot water.
That's true, but a 200-watt DC element would draw less than 15 amps and would make it possible (but slow) to have hot (at least lukewarm )water while motoring.
tibtib is offline
post #12 of 15 Old 05-30-2013
I'm rather confused... your engine circulates its coolant water through the hot water heater, right? But this isn't hot enough for a shower? I realize that having a raw-water cooled engine will likely make it not as warm as the fresh water circuit on my engine, but even the raw water coming out my exhaust is plenty warm enough to shower with (I'd guess about 90 degrees). This isn't what you see?
Others have pretty thoroughly explained the power problems with electrically making hot water while under way, but there's another aspect that hasn't been brought up yet. Even if you did heat your water with electricity, without some plumbing changes, you're still pumping your insufficiently-warm raw water through the hot water heater, which will actually be cooling your hot water!
I plan on having an on-demand propane hot water heater on my next boat for infinite showers, you might want to consider that. There is at least one model approved for use on boats.
1979 Gulfstar 37 Laissez Faire
rmeador is offline
post #13 of 15 Old 05-30-2013
mitiempo's Avatar
A salt water cooled engine has a 140 degree thermostat. But the raw water used to cool the engine doesn't recirculate as with a closed fresh water/antifreeze system and is brought in cold and sent out the exhaust before it gets hot and especially in a cold water area it may never get very hot. You will get luke warm water after a lot of engine time. With the closed fresh/antifreeze system after running for a very short time the coolant is 180 degrees and will heat a tank quickly.
Which on-demand propane water heater is meets ABYC standards for marine use?
rikhall likes this.
Brian
mitiempo is offline
post #14 of 15 Old 05-31-2013
I'm not a marine professional and I have not read the ABYC standards, but my understanding is that most vented on-demand propane water heaters will comply if they are installed in accordance to the ABYC standards -- it's less about the heater itself and more about the installation. That could be a load of crap, I don't know, I haven't done a ton of research into it. This was one of the first that my googling turned up, and the specs seem to imply it can be installed according to ABYC standards: ShowerMate M-550 ? Marine Tankless Water Heater - PrecisionTemp
My friend who has one on his boat is away cruising at the moment, so I can't ask him what brand he has.
rmeador is offline
post #15 of 15 Old 05-31-2013
mitiempo's Avatar
I have been to that link before and it looked to be the best available. But they do not say whether it actually meets ABYC standards, only that it must be installed to those standards. ABYC wants a totally enclosed combustion chamber that is not open in any way to the boat interior. Also pilot lights are not allowed. On the entire site I couldn't find any pictures of the water heater.
If it can meet the standards, possibly by installing it in a vented locker like a propane tank, it might work. I once owned a Rinnai water heater and instant propane water heaters are the most convenient as far as use. You just have to be sure your insurance company is ok with it.
From their website:
Brian
mitiempo is offline
Atlantic Marine Hot Water Tank and Fresh Water Winterization Dcneuro Gear & Maintenance 5 12-17-2012 12:03 PM
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 06:38 AM
Smelly water from fresh water tank Bruce_Olson Gear & Maintenance 20 09-01-2007 05:42 PM
Heating Water with an Inverter Stormer Gear & Maintenance 17 06-19-2007 08:14 AM
Refrigeration -Using the water tank as a cooling water source HenryRusty Gear & Maintenance 7 03-29-2007 01:14 AM
