Inverter for hot water tank - SailNet Community
 1Likes
post #1 of 15 Old 05-19-2013 Thread Starter
old guy :)
rikhall's Avatar
OK - I am asking this because I do not know. This is not a stupid question - teach me something.
I have an Irwin Citation 34 with a 2QM20 raw water cooled Yanmar and attached is an engine warmed hot water tank. The tank is also wired to shore power 120 V AC.
What would be the problem of using an inverter to make 120V AC while motoring to heat the tank water up?
Not all the time - just before we want showers.
Thanks
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #2 of 15 Old 05-19-2013
Re: Inverter for hot water tank
Nothing, so long as you have a large battery bank and a large alternator and are able to provide the 140 amps charging current to maintain the battery SOC.
(Assumes 1500 watt element and an inverter draw of 1500/12 x 1.1)
Bill
btrayfors is offline
post #3 of 15 Old 05-19-2013
Mermaid Hunter
SVAuspicious's Avatar
If you already have an engine coolant loop you will find the water is heated better that way then running the engine to keep the batteries up to support an inverter to heat water.
If you are going to do an upgrade at all I would add a heat exchanger and shift to fresh water cooling of the engine. This will prolong the life of your engine block and head and also increase the temperature of the water in your water heater.
SVAuspicious is offline
post #4 of 15 Old 05-20-2013 Thread Starter
old guy :)
rikhall's Avatar
OK - maybe I was not clear enough - sorry.
1 - it is a raw water cooled Yanmar 2QM20 engine so the water does not get very hot
2 - I do not want to use this while at anchor to heat the water
3 - I was only curious about using it while under way by power (we do get days when we have to motor - not wind or wind in the wrong direction) I though if it was viable we could have hotter water when we got to the anchorage to have our showers.
I do not want to install a heat exchanger because of the cost.
Thanks
rik
Irwin Citation 34
Mystery
rikhall is offline
post #5 of 15 Old 05-20-2013
Maine Sail's Avatar
As Bill stated above unless you have an alt that can support the load or 85-90% of it you will be running a big deficit on your bank even with the engine running.
Even if we figure you have the 60A Yanmar alt, likely not, and we also "assume" it could actually run at 60A, which it won't, you are still losing 90A.
Bill likes to use 1.1 as an efficiency factor for a heater element/inverter and with some inverters this is true but I fudge on the side of caution and use a 1.2 efficiency multiplier...
1500W / 12V = 125A X 1.2 Eff Loss = 150A load - 60A Alt = 90A draw even with the engine running.. (this is a best case scenario)
In all likelihood a 60A Hitachi will be putting out under 30A when driven hard due to its internal regulator temp compensating and reducing the voltage to cool itself....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #6 of 15 Old 05-20-2013 Thread Starter
old guy :)
rikhall's Avatar
Again, Maine Sail to the rescue. Numbers I can understand.
Thanks mate. It just seemed like a good idea at the time.
We go in the water Thursday. Masts go up on Saturday.
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #7 of 15 Old 05-20-2013
pdqaltair's Avatar
Another way to look at it:
A typical deep cycle battery can store about 1.800 kw-hr of energy or about 6100 BTUs. However, only 40% of this safely useable, so about 2440 BTUs.
Warming 10 gallons from 65-105F takes about 3300 BTUs.
Thus, each shower would flatten about 1 1/2 batteries. Different showers and different batteries change the calculation.
Batteries just don't store that much energy, not like liquid fuels (130,000 btus/gallon for diesel). Only a fraction of an ounce of fuel per charge cycle, the challenge of electric drive.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #8 of 15 Old 05-26-2013
Another option would be to convert the water heater to 12 volt operation by changing the element. Here's an example 6 Inch 12 Volt DC Submersible Water Heater Element 6 Inch 12 Volt DC Submersible Water Heater Element [430] - $49.98 : Missouri Wind and Solar, DIY Wind and Solar Energy
tibtib is offline
post #9 of 15 Old 05-28-2013
JimsCAL's Avatar
Unfortunately, this doesn't change the amount of energy that a battery can store and how much water it could heat. Those low wattage elements will only increase (signficantly) the time it takes to make hot water.
JimsCAL is offline
post #10 of 15 Old 05-28-2013
Glad I found Sailnet
Bene505's Avatar
You could always use a lower wattage heater element.
Now that I'm use my extra solar power to get the freezer extra cold... (Goal is no battery usage for the freezer at night.) I'm thinking about running my extra solar to an inverter, driving a lower wattage 120v heater element. It's extra energy anyway, so efficiency matters less.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
Atlantic Marine Hot Water Tank and Fresh Water Winterization Dcneuro Gear & Maintenance 5 12-17-2012 11:03 AM
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
Smelly water from fresh water tank Bruce_Olson Gear & Maintenance 20 09-01-2007 04:42 PM
Heating Water with an Inverter Stormer Gear & Maintenance 17 06-19-2007 07:14 AM
Refrigeration -Using the water tank as a cooling water source HenryRusty Gear & Maintenance 7 03-29-2007 12:14 AM
