replacement batteries - SailNet Community
post #1 of 4 Old 05-23-2013 Thread Starter
Hello
I have 2 AGM batteries on my boat one can no loner be charged and is taking down the other. These batteries sell for $300+ each
I was wondering if i could use nom AGM batteries on my boat and if so what do you reccomend some other boat owners near me are reccomending going to walmart and getting 2 everstarts
I have a picture of the specs on the battery as well but cant upload them
One more wuestion could the battety be the cause for my boat eating zinc
Thank you
Jeremy
Pearson 10m
jhgreen is offline
post #2 of 4 Old 05-23-2013
Irrationally Exuberant
Re: replacement batteries
You can almost certainly go with something other than AGMs. Flooded lead acid deep cycle batteries are probably the best deal out there. You will need to make sure your battery charger is set to charge "regular" batts vs. the AGMs though. You'll find some good threads here on some good deals on deep cycle flooded batts, such as the ones from Sam's Club. I buy mine at Costco.
Unlikely that the bad batt is causing the eaten shaft zinc.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #3 of 4 Old 05-23-2013
no longer reading SailNet
Alex W's Avatar
Cabela's has AGMs on sale right now for compelling prices. I picked up two group 24s there last week for under $150 each.
AGMs are better for my boat than SLAs because my tight battery storage location doesn't have room for a proper battery box.
Are you on shore power? A ground loop due to bonding issues on your boat or a neighboring boat is likely what is eating your zinc. A ground isolator is the correct way to fix that issue. Here is a good article on that subject:
http://www.pbase.com/mainecruising/galvanic_isolator
Alex W is offline
post #4 of 4 Old 05-24-2013
mitiempo's Avatar
[/url]
ABYC (and surveyors for that matter) do not differentiate between battery types. Every battery is supposed to be in a proper box.
Brian
mitiempo is online now
Batteries - Replacement asanchis92 Gear & Maintenance 15 04-16-2013 12:12 AM
AGM batteries: Someone using them? PCP Gear & Maintenance 82 03-27-2012 10:28 PM
82 C27 Batteries Wanderer2011 Gear & Maintenance 3 07-29-2011 12:55 PM
AGM Batteries Yofy Gear & Maintenance 10 08-16-2007 02:33 PM
AGM Batteries Plunderer Gear & Maintenance 9 10-21-2006 07:17 AM
