Drain on batteries while on shore power. - SailNet Community
post #1 of 2 Old 05-25-2013 Thread Starter
L124C's Avatar
If I use 12V lights (drawing a couple of amps) while connected to shore power and my (smart) battery charger, does it shorten the life of my batteries, or simply use them as a conduit?
Edit: Accidently posted this thread twice ("Using 12v while on shore power"). Maybe moderators would delete one and combine the the responses? Thanks
L124C is offline
post #2 of 2 Old 05-25-2013
Zanshin's Avatar
Re: Drain on batteries while on shore power.
The power is "pass through" until such time as your consumption exceeds the charging capacity of your smart charger, then the batteries will supply the missing power and get drained, at least until your consumption goes down and the charger can catch up.
Zanshin is offline
Options for Charging batteries while away from the boat OR away from shore power northwestsailor Electrical Systems 3 05-04-2013 12:30 AM
Hooking 110 power cord to shore power? dvuyxx Electrical Systems 16 06-02-2012 10:35 AM
Shore Power sailguy40 Gear & Maintenance 4 05-01-2011 11:53 PM
Both Batteries Drain Even When Only Bank Is Selected pkilty Electrical Systems 21 10-29-2009 07:34 PM
Shore Power and Batteries TxLnghrn Gear & Maintenance 9 11-13-2008 08:52 PM
