Using 12V while on shore power - SailNet Community
post #1 of 2 Old 05-25-2013 Thread Starter
L124C's Avatar
If I use 12V lights (drawing a couple of amps) while connected to shore power and my (smart) battery charger, does it shorten the life of my batteries, or simply use them as a conduit?
L124C is offline
post #2 of 2 Old 05-25-2013
Re: Using 12V while on shore power
Use all the 12v stuff you want. Usually a smart charger will just kick up its output to accommodate the extra load. This will happen until you exceed the capacity of the charger, after which the batteries will supply the needed power.
Bill
btrayfors is offline
The Following User Says Thank You to btrayfors For This Useful Post:
Maine Sail (05-25-2013)
Hooking 110 power cord to shore power? dvuyxx Electrical Systems 16 06-02-2012 09:35 AM
shore power deniseO30 Electrical Systems 19 03-24-2011 09:52 AM
Non-US Shore Power coyotejack Cruising & Liveaboard Forum 6 03-21-2011 10:37 AM
!@$%!%!! Shore Power! SEMIJim Gear & Maintenance 30 08-17-2007 12:58 PM
shore power NewsReader Mass Bay Sailors 0 02-01-2007 10:15 AM
