Let's start with the storm jib and begin by making it absolutely clear that a rolled-up headsail reefed down to storm-jib size is not an adequate storm sail. It's probably not built to take the abuse that a gale can dish out and if it is, it will not be of any use to you unreefed. You need a sail that is properly designed and engineered for storm conditions, and you need a firm and fixed place to attach it. That means, if possible, an inner forestay (without a rolled-up sail on it) and two padeyes on deck for the sheeting points. There's a product called the Gale Sail (see sidebar) that conveniently fits over a rolled-up sail, but for my money nothing beats an old-fashioned, hanked-on storm jib.
Many sailors leave storm preparation until it's too late and the approaching storm is upon them. I too have been guilty of this. Apathy often gets us into trouble and sailors who have a rolled-up headsail to get down before setting their storm jib will find themselves with greater difficulties as the unrolled sail becomes unmanageable. Before a storm approaches—and if you're truly prudent, before you leave the dock—it's a good idea to set both storm sails so that you are familiar with their sheeting positions and can mark reference points on the halyard and the deck. These reference points will allow you to know exactly where and how the sail sheets before the conditions get rough and it's too late for trial and error. What you do is hoist your storm jib and make sure that there is a short strop or pennant at the tack so that the sail is up off the deck allowing waves to crash underneath it. With the strop in place, make sure that your sheeting point on deck is in the right location. If necessary, lengthen or shorten the strop so that the sheet hits the padeye when the sail is trimmed tightly. I always recommend that storm-strength padeyes be mounted on the deck of an offshore cruising boat for sheeting points. If these are adequately supported by backing plates and the sail is hanked on, then you shouldn't have to worry about anything breaking. I would also suggest that you have a separate set of storm sheets permanently attached to the storm jib so that you are not looking for sheets and trying to attach them once the wind is up. Also, the sheets will have less wear and tear on them this way, giving you the peace of mind that they are strong enough for the job.
Many old salts will tell you that it's a good idea to run the trysail track all the way down to the deck where you can leave the trysail in its bag with the slides permanently mounted on the track. There is definitely some merit to this, but I would point out that in over 200,000 miles of offshore sailing, I have only had the occasion to set a storm trysail twice. So, keeping it on deck means the sail will spend a lot of time getting in the way and baking in the sun. On the other hand, it will be there when you need it, so it's really up to the boat owner or skipper to decide—and it depends on that person's nature and the kind of sailing they plan to do. As Hurricane Florence continued its approach to Bermuda, I was happy to be tied to the dock there. There would be no need for storm gear that night, but if there had been, I was ready. I have done a dry run, practiced setting the sails at the dock and I knew where both sails were intended to be sheeted. My advice to you is that next time the wind goes light and you are wondering what to do, freak out your neighbors by setting your storm sails. At least you will be prepared when the next gale comes your way.
Suggested Reading:
Requirements for Shorthanded Mainsail Handling by Beth Leonard
Storm Tactics by John Kretschmer
Christmas Winds Teach Lessons by Beth Leonard
SailNet Store Section: AirForce Sails
