Blogs
Go Back   SailNet Community > Featured Articles > Gear and Maintenance Articles
User Name
Closed Thread
Old 10-13-2000
Tom Wood Tom Wood is offline
Contributing Authors
Tom Wood is on a distinguished road
Old Hull, New Gelcoat
My hull is dull and faded. Can I refinish it with gelcoat?
Tom Wood responds:
Spraying an old hull with new gelcoat is possible, of course, but would probably require a great deal of finish work to get the desired "new boat" look. Brand new boats are often damaged coming out of the mold or during the process of installing engine, interior, or deck. Many newer designs with the "roll-over" transom corners have the joint between hull and deck filled and coated with gelcoat to gain a finished appearance. But sanding, polishing, and waxing the rough male surface gelcoat to a high-gloss surface is an art, takes considerable time, and is therefore very costly. Good finishers are always in great demand and short supply at major boat builders.
Filling the porosity with an aggressive epoxy primer, sanding fair, and coating with a sprayed or rolled-and-tipped two-part polyurethane paint is still the best option for most boat owners in this situation. It is the least expensive way to get the desired look, and will last nearly as long as the original gelcoat.
Closed Thread
vB code is Off
Page generated in 5.7705 seconds (97.17% PHP - 2.83% MySQL) with 14 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
