Sticky-back Dacron is to the sailmaker what duct tape and epoxy are to a boat builder, an indispensable item. It comes in various weights, but the three-ounce weight is the most versatile and, for some reason, has the best adhesion. You can build up to the required weight by layering the Dacron, and the best part is that by layering you do not end up with a hard spot at the edge of the patch, which could become a hinge and form a weak spot in the sail.
Use sticky-back for repairing all Dacron sails, and for a quick fix on spinnakers. You'll find that it does not work for a long-term repair on Nylon because Dacron and Nylon stretch characteristics are disimilar and the Dacron patch will form a hard spot in the Nylon sail, which will end up ripping after a while.
The key to good sail patching is to lay the ripped area out flat, piecing the edges together where you want them to be when the sail is repaired. Use the underside of one of your wooden floorboards for a flat surface and secure the fabric using sailmaker's awls, or if you prefer, regular pushpins. Trim off any frayed edges and pulled threads to allow the fabric to lay flat. In some cases it might be necessary to cut a square piece out to eliminate the ripped or chafed area if doing so will allow the rest of the fabric to lay flat. Then cut strips of sticky-back wide enough to cover the gap, and carefully place them over the torn area. When using sticky back, it's important to work from the center of the sail out toward the edges so that if your repair does not match up exactly, you can trim off the excess fabric. If you work in toward the middle of the sail and end up with a pucker, you will not be able to trim the excess. Remember, it's important that the repair come out as smooth as possible, so pay careful attention when pinning the sail to the board. A hard spot will soon become a weak spot. When repairing a Dacron sail, decide how many layers of sticky-back you will need to build up to the required fabric weight and layer them over your initial patch making each successive layer larger than the one before. Also, patch both sides of the sail. If you are repairing a rip in the middle of the sail, and you are able to clean and dry the sail before patching it, you will not need to sew the patch. Just lay an extra large patch over the area, allowing the adhesive to hold it all together. The adhesive working in sheer is better than holes poked in Dacron and cinched with waxed thread.
If you are sewing through an area of heavy material, you might want to bang holes in the fabric with a hammer and an awl before sewing. For some repairs, it helps to snap the sharp end off your needle and sand that to a blunt point. Doing this will allow the needle to follow the hole that you made with the awl rather than attempting to make a new one. When it comes to patching a spinnaker, some preplanning is necessary. Because most spinnaker blowouts cover a large area and the space you have on board for repairing them is relatively small, you need to sketch the repair on a pad before starting. This will give you an idea of how the patch will look and allow you to start your repair work from the center of the sail. As previously noted, sticky-back Dacron works well as a temporary repair on a Nylon sail. Here again, make extra wide patches for tears near the leeches, and sew the leech tape back on, either with a sewing machine or by hand. If you are planning on doing a proper, more permanent repair on a Nylon sail, start with a temporary patch made of sticky back. This temporary patch will hold the repair together while you make the final patch with Nylon. The Nylon patch will have to be wider than the temporary patch that you made. Once the temporary patch is supporting the lightweight Nylon to its original shape, turn the sail over and patch it properly with strips of nylon cut from the same weight fabric. Cut pieces that change direction at each seam so that the threads of the patch line up with the threads of the sail. Then lay double-stick tape down the edges of each permanent patch. Remove the backing on the double-stick tape and lay the fabric down smoothly, sweeping it with gentle, outward strokes, and then sew these Nylon patches with your sewing machine. Once the Nylon patches are sewn down, turn the sail over and snip away the temporary patch with scissors. Cut along the edge of the stitching on the permanent patch, removing the damaged original spinnaker cloth and sticky-back temporary patch at the same time. When the old cloth and patch are removed, sew a row of stitching down the seams and across the new patch to hold it all together and aid the transition of the patch into the sail. If you run out of sticky-back and double-stick tape, you'll find that spray adhesives work quite well to hold the fabric in place. However, you will have to sew the patches down since the spray glue does not have a strong enough bond. If a corner ring pulls out of one of your sails, you can replace it with a spare ring. Eyeball the position of the ring and lay strips of two-inch nylon webbing through the ring and onto the sail. Use double-stick tape to hold the webbing in place, and stagger the ends of the webbing so that their transition into the sail is gradual. Then hold the entire repair together with a layer of sticky-back Dacron, since it will be easier to sew the webbing if everything is held in place. Follow the same procedure of banging holes in the webbing with an awl and sewing with blunt needles. Do a few rows of zigzag stitch, being careful to pull each stitch as tight as you can.
Another kind of sail repair is necessary when battens chafe through the pocket of a sail. If this happens, you will have to lift the material that makes up the batten pocket and peel it back as far as the chafed area. Once the hole is exposed, patch it as you would any Dacron sail, adding extra layers of fabric for future wear, and then lay the batten pocket back down over the repair. You probably will not need to sew the patch, but you will need to sew the pocket back down. When repairing the forward end of a batten pocket, pay careful attention to the area where it can snag on a halyard and lift off the sail again. A simple, straight stitch hand-sewn along the edges of the pocket will be sufficient. It is possible to affect a temporary repair to a sail, especially a Dacron sail, using just a needle and thread. Follow the same procedure for cleaning up the tear, removing frayed edges and snagged threads, and then suture the tear closed. Don't attempt to get each stitch the right tension wait until you have finished sewing before laying the sail flat and pinning it with your pushpins. Working down the row of stitches, tension each one until the patch is evenly tensioned. Over-tensioning or under-tensioning a stitch can result in a hard spot, and just like on a regular patch, it will become a weak spot in the repair. Like any other aspect of sailing, practice will help, along with a little delicate handling of the fabric to get it to lie down smoothly. Remember to use layering in order to transition the repair, and don't allow hard spots to develop. Keep your fabric clean and hand-sew the areas near the edges of the sail, and the repair should allow you to make your next port of call safely.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | Search this Thread |
