Safety Equipment for Offshore Sailing - Page 4 - SailNet Community
 1Likes
post #31 of 36 Old 04-13-2014
MarkofSeaLife's Avatar
Dock
Re: Safety Equipment for Offshore Sailing
I think thats one of the reasons why electronic flares will tske over... You can test thrm quivkly.
The prices will come down
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #32 of 36 Old 04-13-2014
Maybe the SoS seminar was trying to demonstrate flare failures? (G)
Mark, I don't know of any electronics that can project a light source up into the sky. (Shine a light, yes, but actually put the source up there for all to see? No.) Lasers are kinda useless unless there's something for them to illuminate or reflect from. Good replacement for a signal mirror...but very different from a parachute flare or smoke bomb.
And then again, I've also seen a number of flashlights, including "extra durable" dive lights, that found clever ways to fail simply sitting on the shelf. Some batteries emit gas as they age, which tarnishes metal contacts in the light and prevents all power flow. Some plastics simply let go as they age, either cracking or popping off the contacts. So even without capacitors failing or cold solder joints...electronics have to be regularly tested. Of course you can't "test" a pyro without consuming it, so maybe there's nothing really lost there. But the pyros have so many fewer ways to fail. And the flares...you know, [I]every [/I]joker has a green laser to shine up at aircraft these days. At least when you see a SOLAS parachute flare, you can be pretty certain there's a reason someone just sent a hundred dollar bill up in flames.
hellosailor is offline
post #33 of 36 Old 04-13-2014
Dock
Come on, get with the news
The electronic flares are out on the market.
Have a look at this video from Yachting Monthly and the Practical Sailor review
http://www.yachtingmonthly.com/videos/gear-tests/533950/video-odeo-laser-flare-test
http://www.practical-sailor.com/issues/37_33/chandlery/The-ODEO-Laser-Flare_11213-1.html
http://www.odeoflare.co.uk/technical.php
Sea Life
post #34 of 36 Old 09-11-2014
krisscross's Avatar
How about launching a kite with a small red strobe light as a distress signal?
Plato
krisscross is online now
post #35 of 36 Old 09-11-2014
kriss, even if you used a huge kite, who would associate a blinky red light UP THERE with a sailboat in distress down here?
(And to be a [I]distress [/I]strobe, it would have to be white anyway.)
post #36 of 36 Old 09-11-2014
Señor Member
ottos's Avatar
[quote=krisscross;2180905]How about launching a kite with a small red strobe light as a distress signal?[/quote]
As you wish - http://www.landfallnavigation.com/-skite.html
Hey, where'd the link button go?????
ottos is offline
Cruising Multihull Sail Trim Kevin Jeffrey Buying a Boat Articles 0 10-05-2004 09:00 PM
Offshore Safety Made Simple Liza Copeland Cruising Articles 0 03-05-2002 08:00 PM
Equipment for Ocean Sailing Mark Matthews Cruising Articles 0 09-18-2000 09:00 PM
Safety Check Mark Matthews Learning to Sail Articles 0 01-25-2000 08:00 PM
Single-Handed Sailing John Kretschmer Seamanship Articles 0 10-19-1999 09:00 PM
BB code is Off
