-   Gear and Maintenance Articles (http://www.sailnet.com/forums/gear-maintenance-articles/)
-   -   Basic Rig Tune for Most Sailboats (http://www.sailnet.com/forums/gear-maintenance-articles/33204-basic-rig-tune-most-sailboats.html)
Dan Dickison 06-04-2007 07:46 AM
<div id="content"><h1>Basic Rig Tune for Most Sailboats<br> by Dan Dickison</h1><img src="http://www.fxsails.com/img/rigtune.jpg" alt="new sails on a Catalina" hspace="5" vspace="5" border="0" align="left"><p>Where I live&mdash;on the southeastern coast of the U.S.&mdash;spring is definitely in the air. Sweet-smelling confederate jasmine is in full bloom, the days are warm and the nights are cool, and local boats are slowly becoming more and more active. This is the time of year when anticipation about the impending sailing season swells and owners profess excitement about the new gear theyíve acquired over the winter. Veteran sailboat owners will tell you much of that excitement pertains to new sails. But sails alone (new or old) shouldnít be any ownerís sole focus right now, particularly after a period of time when you havenít used the boat much.</p><p>Typically, springtime for sailboat owners is a double-edged sword. Itís tinged with all that aforementioned anticipation about days to come on the water, but it also means work&mdash;work getting your sail-handling systems ready, making sure the engine is up to snuff and the bottom paint is attended to, that sort of thing. And regardless of whether you sail a Swan 56 or a Catalina 22&mdash;or anything in between&mdash;if the rig in your vessel isnít somewhere close to being in tune, all that other work wonít amount to much when it comes time to set your sails.</p><p>Rig tune is a simple phrase used to encompass a concept that can be as complex or as straightforward as you want to make it. Essentially, any boat will benefit from having its mast(s) in the right position in the boat with the proper amount of tension applied to the shrouds and stays. Just accomplishing this elementary level of rig tuning will help you prolong the life of your sails, your rig, and your boat. And donít be afraid to seek guidance beyond the scope of this article. Proper rig tune varies from design to design, so the advice herein is intentionally general.</p><p>A number of elements can affect rig tune, including the condition (the shape) of the sails, the nature of the mast, and the age of the boat. To give you a better idea of what that means, consider the words of rigger extraordinaire Brion Toss, who likes to explain that rig tune is all about relationships. ĎWhen you alter the tension on one member, that affects something else.í Iím paraphrasing here, but essentially thatís the idea: Loosen the starboard lower on a single-spreader rig and youíll end up with a mast that bows to port. Loosen the headstay on a masthead rig and you get more forward bend in the middle of the mast, etc. So, to get your rig tunedóor at least in the ballparkóhereís a step-by-step primer:</p><p>1. Start by making sure that all your turnbuckles function properly. And while youíre at it, take a moment to lubricate them. (Some riggers specify Lanocote, others suggest Teflon or SeaLube, and some swear by Wichinox, and thatís just a sampling of the products that are available.)</p><p>2. Then, back off the turnbuckles so that each shroud or stay is slightly floppy. If a tuning guide exists for your boat, consult that to determine just how much rake (the fore and aft inclination of the top of the mast) your rig should have. If no tuning guide exists, make the headstay turnbuckle hand tight, and keep in mind that this affects the rake of the mast. (Some boats donít have an adjustable turnbuckle on the headstay. If thatís the case with your boat, no problem, itís one less adjustment to worry about.)</p><p>3. Now, use the main halyard to determine if the masthead is centered in the athwartships direction. To do this, you simply cleat the halyard off and use the end you normally attach to the head of the mainsail to measure how far the masthead is from the chainplates on either side of the boat. At this stage, you intermittently tighten the upper (or cap) shroud turnbuckles by hand and keep measuring until the masthead is equidistant from the port and starboard chainplates and the cap shrouds are snug. Then tighten the turnbuckles on each upper shroud until the shroud is taut. Usually that means turning them an equal number of turns.</p><p>4. At this stage, you can check your work by sighting up the aft side of the mast to determine if the mast is straight. If it is straight (the spar doesnít bow to one side or the other), good work, youíve got the mast ďin column.Ē If it bows, you simply tighten the lower shrouds correspondingly (or the intermediates if your rig has them) to take out the bow. But donít over-tighten. Remember, tension on the shrouds (and the intermediates) affects the fore and aft bend of the mast as well, and youíre simply trying to get the spar into a straight position at this stage. </p><p>5. Now, sight up the mast from one side or the other to check the fore and aft bend (whether or not the center of the mast is jutting forward). If thereís no perceptible bend, thatís fine. If thereís a slight bend, thatís fine, too. Once you get to this stage, you can begin tightening the lower shrouds by turning them an equal number of turns on each side. As you do this, check to see if the mast remains straight (in column) and adjust accordingly if it doesnít. If your rig has a single set of lowers, tighten them until they are just tighter than the upper shrouds. If youíve got two sets of lowers, make them slightly looser than the upper shrouds. If your rig has intermediate shrouds, these, too, should be slightly tighter than the upper shrouds.</p><p>6. At this juncture, your rig tune should be somewhere in the ballpark, at least enough so that you can safely have a look at how that setting performs under sail. Of course, this is best done in light to moderate breezes. When you do this, take the opportunity to note how loose the leeward shrouds are when youíre underway close-hauled. And get someone to take the helm for you while you sight up the mast to determine whether or not the middle of the mast sags to leeward or the top of the mast drops off noticeably. These assessments are all clues. Too much looseness in the leeward shrouds and youíll need to be tighten them; too much mid-mast sag to leeward and the weather-side lower shroud should probably be tightened.</p><p>If you really want to get serious about rig tune, thereís a lot of good information available in print and online, and most experienced riggers can guide you through the basics. But keep in mind that even though your shrouds and stays are fashioned from stainless steel, this material does stretch (if only in minute percentages) and it definitely fatigues over time. The most productive step any owner can take regarding rig tune is to keep an eye on it. Be aware if your mast is out of column and consider what might have caused that if that is the case. If thereís a turnbuckle thatís slowly loosening due to vibration, youíll almost certainly end up with lousy rig tune, and thereís a good chance you might wind up without any rig at all.</p> <hr><p><i>About the Author: Dan Dickison is known throughout the sailing community for his in-depth articles on a variety of sailing topics. His resume includes stints as a staff editor at Sailing World, Editorial Director of SailNet, and Editor of Practical Sailor. In those capacities he has written principally about racing, sail handling, and maintenance. He has also written over 50 freelance articles that have appeared in major sailing publications around the world.</i></p>
shamrok 04-22-2009 12:29 AM
More basic
I have purchased a 1974 22' O'day. The guy I bought it from sailed it last in Sept 08. He told me everything is ready to go. I have only sailed a handful of times. When I stepped the mast the shrouds were solid but the forestay and backstay seemed a little sloppy. The turnbuckles are taped so I can't see where they would have been adjusted since the last sail. My question is very general "is this safe?" I have no plans to race or try and get every last knot out of the boat right now, I just want to get out and would like some advice on wheather they should be tightened a bit or if it can be sailed with slightly loose forestay and backstay. I can balance myself with them it is not like I would fall over if I grabbed one on the way down. Will this be dangerous if the wind picks up or can it be sailed this way in light to mid winds?
Thanks
Shamrok
Houze66 05-12-2009 06:38 PM
I have a Luders 36 ketch, wood masts; the stays are 3/16" and in good condition; but I wonder if I should go up to 1/4" stays? I do not know the wrap/core count of the existing stays. Any advice?
dorothy 05-13-2009 11:45 PM
Thanks
Shamrok
I once owned a 22' O'Day and feel I should mention that the connection from rudder to hull is ridiculously weak. The rudder, at least on mine, came from the manufacturer clamped to the hull with four tiny screws. No thru-bolts, backing plate or anything. They just drilled those little screws right into the fiberglass. Well, obviously it didn't last long. I barely made it through the first sail from Hyannis to Nantucket. And the rigging connections were no more solid than the rudder. On the plus side, the hull was bulletproof, so I went ahead and paid to have everything re-rigged and never had another problem. I paid $5000 for mine brand new and had to put another boat buck into making it durable enough to actually sail in open water. You get what you pay for, I guess. I bought the boat before I knew anything about boats because my family liked the cockpit.
jmolan 09-15-2009 11:30 AM
Houyze66, there is a guy right there in Phoenix who can run the numbers for you and let you kow if you should re-size. Generally it is not a good idea (for a lot of reasons)
Also he is very good at discussing any rigging you might want to change.
http://www.colligomarine.com/
John is available by phone most any time.
jmolan 09-15-2009 11:35 AM
Originally Posted by Dan Dickison (Post 151922)
<div id="content"><h1>Basic Rig Tune for Most Sailboats<br> by Dan Dickison</h1><img src="http://www.fxsails.com/img/rigtune.jpg" alt="new sails on a Catalina" hspace="5" vspace="5" border="0" align="left"><p>Where I live&mdash;on the southeastern coast of the U.S.&mdash;spring is definitely in the air. Sweet-smelling confederate jasmine is in full bloom, the days are warm and the nights are cool, and local boats are slowly becoming more and more active. This is the time of year when anticipation about the impending sailing season swells and owners profess excitement about the new gear they’ve acquired over the winter. Veteran sailboat owners will tell you much of that excitement pertains to new sails. But sails alone (new or old) shouldn’t be any owner’s sole focus right now, particularly after a period of time when you haven’t used the boat much.</p><p>Typically, springtime for sailboat owners is a double-edged sword. It’s tinged with all that aforementioned anticipation about days to come on the water, but it also means work&mdash;work getting your sail-handling systems ready, making sure the engine is up to snuff and the bottom paint is attended to, that sort of thing. And regardless of whether you sail a Swan 56 or a Catalina 22&mdash;or anything in between&mdash;if the rig in your vessel isn’t somewhere close to being in tune, all that other work won’t amount to much when it comes time to set your sails.</p><p>Rig tune is a simple phrase used to encompass a concept that can be as complex or as straightforward as you want to make it. Essentially, any boat will benefit from having its mast(s) in the right position in the boat with the proper amount of tension applied to the shrouds and stays. Just accomplishing this elementary level of rig tuning will help you prolong the life of your sails, your rig, and your boat. And don’t be afraid to seek guidance beyond the scope of this article. Proper rig tune varies from design to design, so the advice herein is intentionally general.</p><p>A number of elements can affect rig tune, including the condition (the shape) of the sails, the nature of the mast, and the age of the boat. To give you a better idea of what that means, consider the words of rigger extraordinaire Brion Toss, who likes to explain that rig tune is all about relationships. ‘When you alter the tension on one member, that affects something else.’ I’m paraphrasing here, but essentially that’s the idea: Loosen the starboard lower on a single-spreader rig and you’ll end up with a mast that bows to port. Loosen the headstay on a masthead rig and you get more forward bend in the middle of the mast, etc. So, to get your rig tuned—or at least in the ballpark—here’s a step-by-step primer:</p><p>1. Start by making sure that all your turnbuckles function properly. And while you’re at it, take a moment to lubricate them. (Some riggers specify Lanocote, others suggest Teflon or SeaLube, and some swear by Wichinox, and that’s just a sampling of the products that are available.)</p><p>2. Then, back off the turnbuckles so that each shroud or stay is slightly floppy. If a tuning guide exists for your boat, consult that to determine just how much rake (the fore and aft inclination of the top of the mast) your rig should have. If no tuning guide exists, make the headstay turnbuckle hand tight, and keep in mind that this affects the rake of the mast. (Some boats don’t have an adjustable turnbuckle on the headstay. If that’s the case with your boat, no problem, it’s one less adjustment to worry about.)</p><p>3. Now, use the main halyard to determine if the masthead is centered in the athwartships direction. To do this, you simply cleat the halyard off and use the end you normally attach to the head of the mainsail to measure how far the masthead is from the chainplates on either side of the boat. At this stage, you intermittently tighten the upper (or cap) shroud turnbuckles by hand and keep measuring until the masthead is equidistant from the port and starboard chainplates and the cap shrouds are snug. Then tighten the turnbuckles on each upper shroud until the shroud is taut. Usually that means turning them an equal number of turns.</p><p>4. At this stage, you can check your work by sighting up the aft side of the mast to determine if the mast is straight. If it is straight (the spar doesn’t bow to one side or the other), good work, you’ve got the mast “in column.” If it bows, you simply tighten the lower shrouds correspondingly (or the intermediates if your rig has them) to take out the bow. But don’t over-tighten. Remember, tension on the shrouds (and the intermediates) affects the fore and aft bend of the mast as well, and you’re simply trying to get the spar into a straight position at this stage. </p><p>5. Now, sight up the mast from one side or the other to check the fore and aft bend (whether or not the center of the mast is jutting forward). If there’s no perceptible bend, that’s fine. If there’s a slight bend, that’s fine, too. Once you get to this stage, you can begin tightening the lower shrouds by turning them an equal number of turns on each side. As you do this, check to see if the mast remains straight (in column) and adjust accordingly if it doesn’t. If your rig has a single set of lowers, tighten them until they are just tighter than the upper shrouds. If you’ve got two sets of lowers, make them slightly looser than the upper shrouds. If your rig has intermediate shrouds, these, too, should be slightly tighter than the upper shrouds.</p><p>6. At this juncture, your rig tune should be somewhere in the ballpark, at least enough so that you can safely have a look at how that setting performs under sail. Of course, this is best done in light to moderate breezes. When you do this, take the opportunity to note how loose the leeward shrouds are when you’re underway close-hauled. And get someone to take the helm for you while you sight up the mast to determine whether or not the middle of the mast sags to leeward or the top of the mast drops off noticeably. These assessments are all clues. Too much looseness in the leeward shrouds and you’ll need to be tighten them; too much mid-mast sag to leeward and the weather-side lower shroud should probably be tightened.</p><p>If you really want to get serious about rig tune, there’s a lot of good information available in print and online, and most experienced riggers can guide you through the basics. But keep in mind that even though your shrouds and stays are fashioned from stainless steel, this material does stretch (if only in minute percentages) and it definitely fatigues over time. The most productive step any owner can take regarding rig tune is to keep an eye on it. Be aware if your mast is out of column and consider what might have caused that if that is the case. If there’s a turnbuckle that’s slowly loosening due to vibration, you’ll almost certainly end up with lousy rig tune, and there’s a good chance you might wind up without any rig at all.</p> <hr><p><i>About the Author: Dan Dickison is known throughout the sailing community for his in-depth articles on a variety of sailing topics. His resume includes stints as a staff editor at Sailing World, Editorial Director of SailNet, and Editor of Practical Sailor. In those capacities he has written principally about racing, sail handling, and maintenance. He has also written over 50 freelance articles that have appeared in major sailing publications around the world.</i></p>
Dan, I am glad to have found this write up. I really admire your work. And I aspire to the same.
I am a budding (trying) writer who happens to also be a fisherman and rigger. I have a lot of "story" in me. If you get a chance perhaps you can checkout this write up I did. It is my first attempt at writing a "story"
http://www.cruisersforum.com/forums/f116/staying-with-synthetics-30405.html
Too long and ramblin' I am sure. Thanks ahead of time.
jacktherigger at g mail dot com
zz4gta 09-15-2009 12:44 PM
Thanks
Shamrok
I would take the slack out of the forestay and backstay if you don't have an adjustable backstay.
