Blogs
Go Back   SailNet Community > Featured Articles > Gear and Maintenance Articles
User Name
Old 10-14-2008
administrator's Avatar
administrator administrator is offline
Administrator
administrator has disabled reputation
Tune it Up Right with Harken’s RigTune Pro
Harken's Rig Tune Pro has a load cell that measures the rig tension to the nearest kilogram.
With the advent of stiffer hulls and low-stretch rigging, old-fashioned spring-gauge tension meters for measuring shroud tension just don't cut it anymore. Lou Varney, of Diverse Yachts/Tropical Engineering, working with Harken's Andy Ash-Vie, managing director for Harken UK, and Andy Reynolds-Jones came up with a digital tension meter, the RigTune Pro. As rigging is deflected over three pins on the back of the gauge, a load cell records the pressure on one of the pins and measures rig tension to the nearest kilogram. The measurement is displayed on an easy-to-read screen. The RigTune Pro accommodates a specific range of rigging sizes (2.5 to 5 mm), reducing the need for multiple gauges and eliminating conversion tables.The RigTune Pro was recently given a Special Mention at the 2007 DAME Award competition in the Deck Equipment Sails and Rigging category. $297, www.harken.com
Any boat owner knows that an integral part of onboard maintenance is tightening hose clamps. They also know this chore often results in skinned knuckles, tools dropped in hard-to-reach parts of the bilge, and, unless you've got a stronger sense of self control than I, a string of cuss words that would make a pirate proud. Leaping into this technological breach is SMC Innovations, which has introduced the LockDriver, a nut driver that locks on to the head of a hose-clamp screw with the flip of a lever. The LockDriver is available in a range of sizes and shaft lengths with retail prices between $14.95 and $39.95.
LockDriver
Pocket Wrench
SMC Innovations also introduced its take on the ubiquitous multitool, the PocketWrench, which they describe as a "flip" wrench that folds to approximately 5'' long. The PocketWrench is available in both SAE (5/16'' through 1'') and metric versions (8 mm through 25 mm.). www.smc-innovations.com
Because we don't necessarily trust fuel gauges, we've spent a fair amount of time crouched next to fuel vents, hand on the fuel nozzle, ear close to the fuel vent, making sure we don't overfill the tank and spill fuel in the water. To keep us from straining our knees, backs, and ears, there's a new device called the Fuel Whistle. While the tank is being filled, a whistling sound is produced, loud enough to be heard from any point on the boat. As the tank approaches full, the sound turns to a warble. When completely full it stops, and you should do the same. To install, you simply cut your fuel vent line near the fuel tank and insert the Fuel Whistle. $29.95, 516-628-1255, www.greenmarine.com
On a racing sailboat, size and weight matters, and that's why generators like the new Kubota diesel 12 hp Marine Power Unit from Next Generation Power is destined to be a big hit with racers, designers, and builders. Measuring 16'' x 18'' x 21'' and weighing 150 pounds, the 2-cylinder Kubota produces 12 hp at 3,600 rpm, and can be used with a high-output alternator to charge batteries. Heat-exchanger cooled, this compact Kubota features a stainless steel, water-cooled exhaust. Oil pressure and water temperature safety shut downs are standard. $3,495, www.nextgenerationpower.com.
Kubota diesel 12hp marine generator.
See: http://www.sailnet.com/forums/announcement.php?f=9 on how to add a country flag and an avatar to your posts and how to update your forum title.
Old 11-03-2008
TOMINDC2 TOMINDC2 is offline
Old Navy
TOMINDC2 is on a distinguished road
Regarding the fuel whistle -- you got the URL wrong! It is http://www.greenmarineproducts.com/ the greenmarine.com website sells industrial strength ship parts.
CAPT Tom
KatMan2 #992
Gemini 105MC
vB code is Off
Basic Rig Tune for Most Sailboats Dan Dickison Gear and Maintenance Articles 6 09-15-2009 01:44 PM
Roller Furlers SailNet Miscellaneous 0 08-28-2000 09:00 PM
Page generated in 0.5254 seconds (67.58% PHP - 32.42% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
